need a piston part # guru #185222
01/05/09 11:18 PM
01/05/09 11:18 PM
prescottvalley,az
W
wino Offline OP
wino  Offline OP
W
prescottvalley,az
I have a 75' 440 that has been bored to .030 over.
I also have a new set of cast pistons,flat topp's no valve relives cut in them.
they sit at.018 below the deck at t.d.c.
the p/n stamped on top say 2286p .030
I bought these some time back with none of the packing/ boxing etc.
can anyone cross thease pistons like brand,or details such as compression hight etc.
I would like to use them in my 440 since I have them allready have them....please need adice.
wino!
Re: need a piston part # guru [Re: wino] #185223
01/05/09 11:32 PM
01/05/09 11:32 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
it is a sealed power piston..
on nhra list of stock pistons..
says 1.94 for compression height.
Tony
70 AARCuda Vitamin C
Re: need a piston part # guru [Re: 70AARcuda] #185224
01/05/09 11:48 PM
01/05/09 11:48 PM
prescottvalley,az
W
wino Offline OP
wino  Offline OP
W
prescottvalley,az
Thank you 70aar!
Re: need a piston part # guru [Re: wino] #185225
01/06/09 07:23 PM
01/06/09 07:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Something's wrong, with a piston compression height of 1.94" the piston should be down in the hole at least .140". Could the .018" be .180"? (decimal point)
Re: need a piston part # guru [Re: John_Kunkel] #185226
01/06/09 11:14 PM
01/06/09 11:14 PM
prescottvalley,az
W
wino Offline OP
wino  Offline OP
W
prescottvalley,az
The method I used was to put a straight edge across the cylinder resting on the block deck and used a feeler gage to check the piston at t.d.c.
feeler gauge was .018
the piston comes up to almost flush to the deck minus a gap from a feeler gauge of .018
is this correct?
Re: need a piston part # guru [Re: wino] #185227
01/06/09 11:52 PM
01/06/09 11:52 PM
A straight edge & feeler gauges will get you VERY close. 3.75 stroke(divided by 2)is 1.875". An RB rod is 6.768" & your CH of 1.94 gives 10.583 would be .142" in the hole with an advertized (RB)deck height of ~10.725". Whats been altered here.
Re: need a piston part # guru [Re: RapidRobert] #185228
01/07/09 12:02 AM
01/07/09 12:02 AM
prescottvalley,az
W
wino Offline OP
wino  Offline OP
W
prescottvalley,az
so if i undestand corrcetly this bock has been decked quite abit. will this piston / block combo work on a uluminum headed eng. be ok?
Re: need a piston part # guru [Re: wino] #185229
01/07/09 12:05 AM
01/07/09 12:05 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
maybe the compression height is wrong.
it is in a list of acceptable pistons...and all say 1.94 compression height...
Tony
Re: need a piston part # guru [Re: 70AARcuda] #185230
01/07/09 12:37 AM
01/07/09 12:37 AM
It would appear to be though thats an ungodly amt to have been milled from a deck. The stroke & rod length doesn't vary too much & if that is the actual CH of those pistons then there's nothing else. Yes with .018" in the hole & the right gasket you can end up with excellent quench for your aluminum heads but stay on top of what your CR will end up being & enough valve/piston clearance.
Re: need a piston part # guru [Re: RapidRobert] #185231
01/07/09 02:45 AM
01/07/09 02:45 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
here is a copy of the excel file from nhra..scroll down to find the 440 list..
google does not bring up anything on sealed power 2286p.
need to find someone with an old sealed power catalong...
Tony
Re: need a piston part # guru [Re: 70AARcuda] #2287396
04/14/17 12:26 AM
04/14/17 12:26 AM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
n
Re: need a piston part # guru [Re: 70AARcuda] #2287739
04/14/17 04:28 PM
04/14/17 04:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The L2286P is the original forged NHRA replacement piston for the 68-69 440. It has a 2.034" CD
Same piston? I don't know.
You still need to cut the deck a bit to get a 0.018". Probably a 0.030" to 0.040" cut.
