Re: need a piston part # guru
[Re: wino]
#185223
01/05/09 11:32 PM
01/05/09 11:32 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
it is a sealed power piston..
on nhra list of stock pistons..
says 1.94 for compression height.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: wino]
#185225
01/06/09 07:23 PM
01/06/09 07:23 PM
Posts: 25,858 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Something's wrong, with a piston compression height of 1.94" the piston should be down in the hole at least .140". Could the .018" be .180"? (decimal point)
[Re: wino]
#185227
01/06/09 11:52 PM
01/06/09 11:52 PM
RapidRobert
A straight edge & feeler gauges will get you VERY close. 3.75 stroke(divided by 2)is 1.875". An RB rod is 6.768" & your CH of 1.94 gives 10.583 would be .142" in the hole with an advertized (RB)deck height of ~10.725". Whats been altered here.
[Re: wino]
#185229
01/07/09 12:05 AM
01/07/09 12:05 AM
70AARcuda
las vegas
maybe the compression height is wrong.
it is in a list of acceptable pistons...and all say 1.94 compression height...
Tony
[Re: 70AARcuda]
#185230
01/07/09 12:37 AM
01/07/09 12:37 AM
RapidRobert
It would appear to be though thats an ungodly amt to have been milled from a deck. The stroke & rod length doesn't vary too much & if that is the actual CH of those pistons then there's nothing else. Yes with .018" in the hole & the right gasket you can end up with excellent quench for your aluminum heads but stay on top of what your CR will end up being & enough valve/piston clearance.
[Re: RapidRobert]
#185231
01/07/09 02:45 AM
01/07/09 02:45 AM
70AARcuda
las vegas
here is a copy of the excel file from nhra..scroll down to find the 440 list..
google does not bring up anything on sealed power 2286p.
need to find someone with an old sealed power catalong...
Tony
