Street/Strip 904 Build Help
#2285279
04/10/17 01:30 PM
04/10/17 01:30 PM
Porter67
Please help me spec the parts to build a street/mild strip 904 old school retro 80-s build.
Simple 3400lb 76 A body 4.56 rear/28 inch tire.
Simple 450-475 stock stroke 360
Im aware of the front drum/ burnout/ blow up issue id like of stray from that much of an investment because at this power level and use I just cant see it.
Ive a full alto kit, clutches/bands, ect.
A decent old school tci old school vert.
The trans act? valve body kit.
Im keeping it a full functioning valve body (non manual) since its a street driven build.
Im unclear on the lever ratio to get, and if i really need any of the billet servo-s and pistons advertised.
Any input would be greatly appreciated.
Re: Street/Strip 904 Build Help
[Re: Porter67]
#2285507
04/10/17 09:42 PM
04/10/17 09:42 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
999 has 5 clutches in front drum...you can put 5 clutches in the 904 drum by using the thin disc and steels...been there done mucho times.
904 drums don't explode due to there mast...or they are small.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Porter67]
#2285528
04/10/17 10:03 PM
04/10/17 10:03 PM
70AARcuda
las vegas
If you are footbraking...dont worry about adding 5th disc...
Tony
[Re: Porter67]
#2285595
04/10/17 11:57 PM
04/10/17 11:57 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Trans-go shift kit. Have a buddy running 11.0 in a 3400 lb. Dart, with column shift and the #2 kit.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: Porter67]
#2285787
04/11/17 12:29 PM
04/11/17 12:29 PM
Posts: 836 Columbus, OH
65Dodge440
Columbus, OH
I have a 904 in may car with CRT parts that's not a mvb and it's my understanding the line pressure is very critical. I'm using the Lokar cable. Have you thought about what you're going to use? I see Cope offers a cable system, Mancini has one similar but a little different. I'm questioning whether the Lokar is the best option for this.
