Street/Strip 904 Build Help #2285279
04/10/17 01:30 PM
04/10/17 01:30 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Please help me spec the parts to build a street/mild strip 904 old school retro 80-s build.
Simple 3400lb 76 A body 4.56 rear/28 inch tire.
Simple 450-475 stock stroke 360
Im aware of the front drum/ burnout/ blow up issue id like of stray from that much of an investment because at this power level and use I just cant see it.
Ive a full alto kit, clutches/bands, ect.
A decent old school tci old school vert.
The trans act? valve body kit.
Im keeping it a full functioning valve body (non manual) since its a street driven build.
Im unclear on the lever ratio to get, and if i really need any of the billet servo-s and pistons advertised.
Any input would be greatly appreciated.
Re: Street/Strip 904 Build Help [Re: Porter67] #2285310
04/10/17 02:37 PM
04/10/17 02:37 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
You should talk to CRT or A&A Trans; but for reference, my old 904 went several seasons as a basically stock unit with only good clutches & bands, a deep pan and a RMVB. 4400 stall, 3000lb footbrake drag car. Pay attention to the converter hub welded area, had a problem there after getting to 600HP & 5800 stall. That was probably age-related.
At about 640HP, 6000 stall & low 10s, the stock parts were beyond their limits; I stepped up to a CRT 904 and it's been great.
Re: Street/Strip 904 Build Help [Re: Porter67] #2285315
04/10/17 02:41 PM
04/10/17 02:41 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Thanks for the input, its ironic as im trying to sell a crt pro race 727, because im trying to backtrack.
Im really building me a very mild street car with a drive to the track from time to time.
And I very much agree with your statements, way back this trans with just a bs cheap vert and shift kit and nothing else lasted 3 seasons with a mild 360 bracket racing every weekend.
Re: Street/Strip 904 Build Help [Re: Porter67] #2285369
04/10/17 05:28 PM
04/10/17 05:28 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mark you could take the manual valve body out and put in an automatic valve body and use the trans in the car you're building. Just a thought.
Re: Street/Strip 904 Build Help [Re: Porter67] #2285407
04/10/17 06:53 PM
04/10/17 06:53 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Boy am I out of the loop on auto trans and the interchangeability of parts.
The crt trans is out now, Im kinda hellbent on the 904 and just ordered a few more internal parts. And its org to the car.
See I jacked a C4 ford trans when I was 14 and have been skiddish of auto-s ever since. I will do manuals all day long but ive always farmed out auto-s.
Some days I could set the shop on fire and walk away happy.
Re: Street/Strip 904 Build Help [Re: Porter67] #2285474
04/10/17 08:58 PM
04/10/17 08:58 PM
dogdays Offline
dogdays  Offline
The stoutest stock 904-style transmission was the A-999, which came behind 360s, but I'm not sure of the dates or even how to tell which is which. That's a John Kunkel question.
If you are running 4.56s you probably don't need the deep First gear of the later transmissions.
I didn't think the 904-style transmissions had the exploding drum problem.
R.
Re: Street/Strip 904 Build Help [Re: Porter67] #2285507
04/10/17 09:42 PM
04/10/17 09:42 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
999 has 5 clutches in front drum...you can put 5 clutches in the 904 drum by using the thin disc and steels...been there done mucho times.
904 drums don't explode due to there mast...or they are small.
Tony
70 AARCuda Vitamin C
Re: Street/Strip 904 Build Help [Re: Porter67] #2285519
04/10/17 09:50 PM
04/10/17 09:50 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Thanks, mine seems to be the 998 1976 with the 2.45 first gear.
Im kinda on the fence on the 5 clutches since ive already got the thick 4 ones.
Is there that much more holding power vs wear... I know, probably 20% more??
Re: Street/Strip 904 Build Help [Re: Porter67] #2285528
04/10/17 10:03 PM
04/10/17 10:03 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
If you are footbraking...dont worry about adding 5th disc...
Tony
Re: Street/Strip 904 Build Help [Re: Porter67] #2285595
04/10/17 11:57 PM
04/10/17 11:57 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Trans-go shift kit. Have a buddy running 11.0 in a 3400 lb. Dart, with column shift and the #2 kit.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Street/Strip 904 Build Help [Re: Porter67] #2285601
04/11/17 12:12 AM
04/11/17 12:12 AM
sioux falls, sd
10sec.dart Offline
10sec.dart  Offline
sioux falls, sd
If you are going to get a new converter I would go with the a500 style pump neck, that will take away the chance of cracking a neck, ive done it 3 times. you will have to get new pump gears from A@A for that pump neck but its well worth it. ive gone 9.70's with my 904 and its held up. that's about my only issue ive had
Re: Street/Strip 904 Build Help [Re: Porter67] #2285603
04/11/17 12:14 AM
04/11/17 12:14 AM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
just did a 904 a week ago using John Copes advise, i wanted a rmvb so a crt rmvb, 4.2 lever, billet servo rear, replaced the front drum single spring to a crt multispring, and blocker rod in accumalator. i purchased a deep pan from trans parts house for 20.00 the rest of the tranny was rebuilt a couple thousand miles ago. shifts are instant now.
Re: Street/Strip 904 Build Help [Re: Porter67] #2285787
04/11/17 12:29 PM
04/11/17 12:29 PM
Columbus, OH
65Dodge440 Offline
65Dodge440  Offline
Columbus, OH
I have a 904 in may car with CRT parts that's not a mvb and it's my understanding the line pressure is very critical. I'm using the Lokar cable. Have you thought about what you're going to use? I see Cope offers a cable system, Mancini has one similar but a little different. I'm questioning whether the Lokar is the best option for this.
Re: Street/Strip 904 Build Help [Re: Porter67] #2288809
04/16/17 02:01 PM
04/16/17 02:01 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
I do think my kit is the transgo, as far as the kickdown part goes, im going to use the the 6bbl intake/carb setup off my t/a car while its down and have many different configs for an oem type 904 kickdown, luckly on the 6bbl it seems most 2bbl kickdown setups will work.
I also have the mp adjustable kickdown kit, just got to get it all set up right.
