Page 3 of 5 1 2 3 4 5
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2284562
04/08/17 09:33 PM
04/08/17 09:33 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Reused standard rockers when i went to EZs. Also no header issues. -1s have a raised exhaust port. Plus EZ heads are pretty cheap
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2284579
04/08/17 10:11 PM
04/08/17 10:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Ray, were you able to open up that Weiand TR to MW size without building up the outside?
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2284581
04/08/17 10:16 PM
04/08/17 10:16 PM
So. Burlington, Vt.
So. Burlington, Vt.
I'm just sitting back looking at my original plan and saying why not go 440-1's or big easy with a modman that will fit them with EFI, on something like 570" 11.5-1, and a stick around .700 274-282. What are my plans biggest flaws?
No problems with that plan.
It's an 800hp motor with a 700hp induction on it....... should work fine.
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2284592
04/08/17 10:58 PM
04/08/17 10:58 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Fast, it needs to be welded. I bought it from a member here welded up
Re: Recipe for 700hp six pack 440 or bigger- [Re: sixpackgut] #2284631
04/09/17 12:33 AM
04/09/17 12:33 AM
Sask, Can.
72demon416 Offline OP
Sask, Can.
Two good reasons, that's the kind of info I am after- thanks.
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2285092
04/09/17 11:57 PM
04/09/17 11:57 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Rick:
You should find this righteous piece of machinery up your alley:
'70 Cuda, Black Series
The car belongs to John, jbc426 on here.
Mo' Farts
Moderated by "tbagger".
Re: Recipe for 700hp six pack 440 or bigger- [Re: Grizzly] #2285114
04/10/17 01:10 AM
04/10/17 01:10 AM
Sask, Can.
Sask, Can.
Thanks Grizz, John's got a great car there and pretty much what I'm going to do with mine (the previous owner had already started down that path in 82) The guy interviewing/hosting though....that's another story...
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2285161
04/10/17 03:36 AM
04/10/17 03:36 AM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
World block 4,32 bore
Ohio crank 3,76 stroke
Molnar rods
CP 10,5 pistons.
BIG I mean BIG roller cam
T&D 1.65-1.7 rocker arms
Jesel belt
Max ported Mopar stage V heads with 79,5cc chambers with stock size intake and exhaust runners. 2.08-1.74 valves
Custom sheet metal intake
Revers cooling
"Stock" sixpack carbs
738hp 652lbs tourqe
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: Recipe for 700hp six pack 440 or bigger- [Re: MrSixpack] #2285167
04/10/17 04:17 AM
04/10/17 04:17 AM
Sask, Can.
Sask, Can.
Thank You!
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2285204
04/10/17 10:22 AM
04/10/17 10:22 AM
Harleysville, PA USA
Tommy D Offline
Tommy D  Offline
I've heard that above 650-700 HP, RB blocks go boom! For the power level you're trying to attain, you may need an aftermarket block, or at least some help to stabilize the bottom end (Girdle). Good luck with your build.
Re: Recipe for 700hp six pack 440 or bigger- [Re: Tommy D] #2285265
04/10/17 12:49 PM
04/10/17 12:49 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
They go boom only if you use them........crank likes going on vacation through the pan.
Have a great day
Iowan
"obsolete is neat"
Re: Recipe for 700hp six pack 440 or bigger- [Re: Tommy D] #2285309
04/10/17 02:37 PM
04/10/17 02:37 PM
I don't know of any crank girdle that reinforced the main webbing work
It is the main webbing between the bottom of the cylinder walls and the main bearing bores that fails on the RB,440, blocks, not the oil pan rails or main webbing ribs from the oil pan rails shruggy
The girdles can't fix that, new better race block do that well thumbs
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2285320
04/10/17 02:48 PM
04/10/17 02:48 PM
gregsdart Offline
gregsdart  Offline
Would you be willing to put an Indy block in this project? Many advantages, if you will. Weight off the front is a huge advantage for starters. On top of that, 35 less HP should mile an hour as fast.
Re: Recipe for 700hp six pack 440 or bigger- [Re: gregsdart] #2285332
04/10/17 03:30 PM
04/10/17 03:30 PM
Sask, Can.
Sask, Can.
Yeah, It certainly seems like I would be pushing the blocks longevity and that a mega block would be strongly advised. I would like to ultimately go that route, it will just mean that I'll have to wait longer to do this buildup- I'd rather only have do it once though.
Re: Recipe for 700hp six pack 440 or bigger- [Re: Cab_Burge] #2285334
04/10/17 03:45 PM
04/10/17 03:45 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The girdle will keep the main caps from moving around which I would think would put less stress on the webbing ribs. Tying everything together, pan rail, main caps plus a half fill on the block should stiffen things up. But, your still working with a 50 year old block.
Re: Recipe for 700hp six pack 440 or bigger- [Re: 70BIRD] #2285353
04/10/17 04:47 PM
04/10/17 04:47 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Originally Posted By 70BIRD
I just pulled out the invoice from Hughes and it says Stage II porting. From the outside there was definitely no welding or material added.
Paul
I was thinking a max-wedge port, not sure what a stage 2 port is, is that just gasket matched and cleaned up?
Re: Recipe for 700hp six pack 440 or bigger- [Re: RATTRAP] #2285377
04/10/17 05:41 PM
04/10/17 05:41 PM
Sask, Can.
Sask, Can.
Paul
I was wondering about that as well as the website does not say anything about a stage 2 port.
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2285400
04/10/17 06:23 PM
04/10/17 06:23 PM
gregsdart Offline
gregsdart  Offline
IMHO a megablock in cast iron will put a lot of weight on the front, making it very hard to hook. The traction difference for unpreped surfaces is huge!! Go aluminum, or at worst a low deck with a lowdeck sixpack, my opinion on this. If you are also going to have a less than optimal suspension, the situation snoballs some more.
Re: Recipe for 700hp six pack 440 or bigger- [Re: gregsdart] #2285539
04/10/17 10:18 PM
04/10/17 10:18 PM
Sask, Can.
Sask, Can.
Why a lowdeck Greg? What is the advantage?
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2285753
04/11/17 11:01 AM
04/11/17 11:01 AM
Ohio
70BIRD Offline
70BIRD  Offline
Ohio
If you go to the Hughes website on the tab "Instructions & Tech Articles", then "Intake Manifold Articles" and then link #4 you will see a bunch of manifolds they flow tested and give the flow numbers for stock, Stage I and Stage II porting.
Paul
