Re: Recipe for 700hp six pack 440 or bigger-
[Re: 72demon416]
#2284562
04/08/17 09:33 PM
04/08/17 09:33 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Reused standard rockers when i went to EZs. Also no header issues. -1s have a raised exhaust port. Plus EZ heads are pretty cheap
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: 72demon416]
#2284579
04/08/17 10:11 PM
04/08/17 10:11 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Ray, were you able to open up that Weiand TR to MW size without building up the outside?
[Re: 72demon416]
#2284581
04/08/17 10:16 PM
04/08/17 10:16 PM
fast68plymouth
So. Burlington, Vt.
I'm just sitting back looking at my original plan and saying why not go 440-1's or big easy with a modman that will fit them with EFI, on something like 570" 11.5-1, and a stick around .700 274-282. What are my plans biggest flaws? No problems with that plan. It's an 800hp motor with a 700hp induction on it....... should work fine.
[Re: 72demon416]
#2284592
04/08/17 10:58 PM
04/08/17 10:58 PM
sixpackgut
Charleston
Fast, it needs to be welded. I bought it from a member here welded up
[Re: sixpackgut]
#2284631
04/09/17 12:33 AM
04/09/17 12:33 AM
Posts: 1,496 Sask, Can.
72demon416
Sask, Can.
Reused standard rockers when i went to EZs. Also no header issues. -1s have a raised exhaust port. Plus EZ heads are pretty cheap Two good reasons, that's the kind of info I am after- thanks.
[Re: 72demon416]
#2285092
04/09/17 11:57 PM
04/09/17 11:57 PM
Posts: 6,015 Salem
Grizzly
Moparts Proctologist
Salem
Rick: You should find this righteous piece of machinery up your alley: '70 Cuda, Black Series The car belongs to John, jbc426 on here.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2285114
04/10/17 01:10 AM
04/10/17 01:10 AM
72demon416
Sask, Can.
Thanks Grizz, John's got a great car there and pretty much what I'm going to do with mine (the previous owner had already started down that path in 82) The guy interviewing/hosting though....that's another story...
[Re: 72demon416]
#2285161
04/10/17 03:36 AM
04/10/17 03:36 AM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
World block 4,32 bore Ohio crank 3,76 stroke Molnar rods CP 10,5 pistons. BIG I mean BIG roller cam T&D 1.65-1.7 rocker arms Jesel belt Max ported Mopar stage V heads with 79,5cc chambers with stock size intake and exhaust runners. 2.08-1.74 valves Custom sheet metal intake Revers cooling "Stock" sixpack carbs
738hp 652lbs tourqe
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
[Re: MrSixpack]
#2285167
04/10/17 04:17 AM
04/10/17 04:17 AM
72demon416
Sask, Can.
Thank You!
[Re: Tommy D]
#2285265
04/10/17 12:49 PM
04/10/17 12:49 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I've heard that above 650-700 HP, RB blocks go boom! For the power level you're trying to attain, you may need an aftermarket block, or at least some help to stabilize the bottom end (Girdle). Good luck with your build. They go boom only if you use them........crank likes going on vacation through the pan.
Have a great day Iowan
"obsolete is neat"
[Re: Tommy D]
#2285309
04/10/17 02:37 PM
04/10/17 02:37 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
I don't know of any crank girdle that reinforced the main webbing It is the main webbing between the bottom of the cylinder walls and the main bearing bores that fails on the RB,440, blocks, not the oil pan rails or main webbing ribs from the oil pan rails The girdles can't fix that, new better race block do that well
[Re: 72demon416]
#2285320
04/10/17 02:48 PM
04/10/17 02:48 PM
Posts: 10,015 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Would you be willing to put an Indy block in this project? Many advantages, if you will. Weight off the front is a huge advantage for starters. On top of that, 35 less HP should mile an hour as fast.
[Re: Cab_Burge]
#2285334
04/10/17 03:45 PM
04/10/17 03:45 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I don't know of any crank girdle that reinforced the main webbing It is the main webbing between the bottom of the cylinder walls and the main bearing bores that fails on the RB,440, blocks, not the oil pan rails or main webbing ribs from the oil pan rails The girdles can't fix that, new better race block do that well The girdle will keep the main caps from moving around which I would think would put less stress on the webbing ribs. Tying everything together, pan rail, main caps plus a half fill on the block should stiffen things up. But, your still working with a 50 year old block.
[Re: 70BIRD]
#2285353
04/10/17 04:47 PM
04/10/17 04:47 PM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
I just pulled out the invoice from Hughes and it says Stage II porting. From the outside there was definitely no welding or material added.
Paul I was thinking a max-wedge port, not sure what a stage 2 port is, is that just gasket matched and cleaned up?
[Re: RATTRAP]
#2285377
04/10/17 05:41 PM
04/10/17 05:41 PM
72demon416
Sask, Can.
Paul I was thinking a max-wedge port, not sure what a stage 2 port is, is that just gasket matched and cleaned up? I was wondering about that as well as the website does not say anything about a stage 2 port.
[Re: 72demon416]
#2285400
04/10/17 06:23 PM
04/10/17 06:23 PM
gregsdart
Yeah, It certainly seems like I would be pushing the blocks longevity and that a mega block would be strongly advised. I would like to ultimately go that route, it will just mean that I'll have to wait longer to do this buildup- I'd rather only have do it once though. IMHO a megablock in cast iron will put a lot of weight on the front, making it very hard to hook. The traction difference for unpreped surfaces is huge!! Go aluminum, or at worst a low deck with a lowdeck sixpack, my opinion on this. If you are also going to have a less than optimal suspension, the situation snoballs some more.
