Re: 65 Dart Headers
[Re: RBSat66]
#2284895
04/09/17 05:04 PM
04/09/17 05:04 PM
RapidRobert
what headers do you have in mind? there are the Hooker 5208 fenderwells. OT you may or may not have interference at the trans tunnel with a 727 (early A have tolerance issues in some areas but are my favs). Likely the tunnel lip will need to be flattened (best is to grind it off/weld that seam). I would (highly) suggest a 904 but it sounds like you have the eng/trans as a unit or likely it is already in there.
Re: 65 Dart Headers
[Re: RBSat66]
#2284957
04/09/17 07:29 PM
04/09/17 07:29 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
Call TTI to make sure,951-371-4878 after 8:00 AM PDT I have a local customer who is going to need headers for his 1966 Dart GT with a 340 stroker motor with Eddy RPM heads, he is looking at TTI also
Re: 65 Dart Headers
[Re: Cab_Burge]
#2285044
04/09/17 10:32 PM
04/09/17 10:32 PM
RapidRobert
I've heard nothing but good regarding TTI (not for that app but in general). As you know they ain't cheap.
