Re: Torque numbers for aluminum heads
[Re: fal3]
#2284048
04/07/17 05:35 PM
04/07/17 05:35 PM
Posts: 959 Chicago
PurpleBeeper
Chicago
I'm no expert, but I think all the torque numbers are the same as with iron heads. I've heard to make sure you use steel washers under bolts so the bolt heads don't start scratching the aluminum.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: fal3]
#2284222
04/07/17 11:57 PM
04/07/17 11:57 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
IIRC I went to 75 on my Stealths.Been on since they first came out and no problems.Did use ARP bolts and lube and 3 steps.Rocky
Chrysler Firepower
[Re: fal3]
#2284362
04/08/17 12:52 PM
04/08/17 12:52 PM
therocks
Niles , Ohio
Source and Eddys use the same spec.Same with bolts.I agree a dab of anti sieze on plugs and I also use some on the Intake bolts.Same with the exhaust bolts.I run studs even though the holes are dry.Rocky
Chrysler Firepower
[Re: fal3]
#2287114
04/13/17 04:19 PM
04/13/17 04:19 PM
therocks
Niles , Ohio
I agree Ive never torqued the intake exhaust or rockers.Only the heads.But then Im older than dirt and have had tons apart.Same with plugs.Working in the shop you cant believe the amout of plugs that were either loose or so tight you almost need an impact to get them out.But for someone that dosent do it a lot the specs are good.Rocky
Chrysler Firepower
