Axle studs and Weld Drag lites #2282819
04/05/17 01:58 PM
04/05/17 01:58 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I am not drag racing so I want to use closed end lug nuts. Can anyone tell me what length stud I will need on my axles to go with the Weld Drag Lites ?
thanks !
Re: Axle studs and Weld Drag lites [Re: lostdog] #2282869
04/05/17 03:16 PM
04/05/17 03:16 PM
an8sec70cuda Offline
You can use stock length studs. Just get the closed end lugnuts w/ the correct shank length for the Weld rims.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Axle studs and Weld Drag lites [Re: lostdog] #2282886
04/05/17 03:43 PM
04/05/17 03:43 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Look for a lug nut with a 1.380 in. shank. 1/2x20 thread.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Axle studs and Weld Drag lites [Re: an8sec70cuda] #2282934
04/05/17 05:12 PM
04/05/17 05:12 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Ok - great. That's what I was hoping but I wasn't sure. Thanks for your help !
Re: Axle studs and Weld Drag lites [Re: 71yelladustr] #2282935
04/05/17 05:12 PM
04/05/17 05:12 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Thank you !
Re: Axle studs and Weld Drag lites [Re: lostdog] #2283989
04/07/17 03:35 PM
04/07/17 03:35 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I would not use stock studs with thick center Welds. If I had to use closed end nuts, only the long ones that are long enough to go all the way through the wheel, I would get 3" studs and cut them to length to use most or all of the nut without bottoming.
Re: Axle studs and Weld Drag lites [Re: CMcAllister] #2284023
04/07/17 04:43 PM
04/07/17 04:43 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Yes, I will be using a lug nut that has a shoulder compatible with the thickness of the hub on the wheel.
Re: Axle studs and Weld Drag lites [Re: lostdog] #2284037
04/07/17 05:05 PM
04/07/17 05:05 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I know you said you wouldn't be racing, but for safety reasons the rule book specifies that a 1/2" stud extend at least 1/2" into the hex part of the nut. I would want the see it extend out of the wheel some. If nothing else, it's easier to get the nuts started on.
