Modified oil pump failure #2282446
04/04/17 08:57 PM
04/04/17 08:57 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
This weekend did not end up so good.. although I guess we could say it could have been worse.. the Car slow down almost for tenths on its last pass.. after picking up my losing time slip.. re fired the motor and noticed it didn't have any oil pressure.. and the starter really struggled to start it... I got it home.. remove the oil pump and found the oil pump Lane in the oil pan
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Modified oil pump failure [Re: WHITEDART] #2282452
04/04/17 09:08 PM
04/04/17 09:08 PM
bean town ....Ca
W
W
bean town ....Ca
One more
Re: Modified oil pump failure [Re: WHITEDART] #2282456
04/04/17 09:12 PM
04/04/17 09:12 PM
bean town ....Ca
W
W
bean town ....Ca
The two main caps that I have removed look perfect bearings are beautiful... five of the rods bearings are in great shape.. three of the rod bearings were to The Copper. And two of the rod caps show signs of heat...
Re: Modified oil pump failure [Re: WHITEDART] #2282463
04/04/17 09:18 PM
04/04/17 09:18 PM
oregon
greendart408 Offline
oregon
Sorry about your misfortune, came out from it ok by the looks of it considering. Was the pump bottomed on that stud? Or just flat break in half for zero reason?
Re: Modified oil pump failure [Re: WHITEDART] #2282465
04/04/17 09:24 PM
04/04/17 09:24 PM
Canada
onig Offline
onig  Offline
Canada
Do you know why it broke? Was the pick up tube under stress and caused the casting to break off?
69 Dart
Re: Modified oil pump failure [Re: WHITEDART] #2282475
04/04/17 09:44 PM
04/04/17 09:44 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Sounds like you caught it just in time except for a couple rods and cleaning up the crank what kind of rods are you using
Re: Modified oil pump failure [Re: scottb] #2282481
04/04/17 09:54 PM
04/04/17 09:54 PM
bean town ....Ca
W
W
bean town ....Ca
Oliver rods and a king crank..there was no interference between the main cap and the oil pump... however the pump passage was greatly increased in size...
Re: Modified oil pump failure [Re: WHITEDART] #2282514
04/04/17 10:38 PM
04/04/17 10:38 PM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
That is a shame but could have been worse. What are the specs on the Oliver rods?
Howard
Re: Modified oil pump failure [Re: mrsmallblock] #2282520
04/04/17 10:48 PM
04/04/17 10:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Sorry to see this but I'm glad you caught before things turned ugly
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Modified oil pump failure [Re: WHITEDART] #2282532
04/04/17 10:56 PM
04/04/17 10:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Whats your peak oil pressure
wave
Re: Modified oil pump failure [Re: WHITEDART] #2282537
04/04/17 11:03 PM
04/04/17 11:03 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not sure if this is the exact same problem, regardless worth checking whenever in the area, look at Pic #19
https://board.moparts.org/ubbthreads/ubbt...tml#Post1554264
IMO on further review, the enlarged oil passage likely was the initiator of this failure, by weakening the lower oil pump support structure.
edit #2 and the oil pan crushing wheel stand. grin
Re: Modified oil pump failure [Re: mrsmallblock] #2282546
04/04/17 11:13 PM
04/04/17 11:13 PM
bean town ....Ca
W
W
bean town ....Ca
Howard
6.250 long. 9.27 2.100
Re: Modified oil pump failure [Re: MR_P_BODY] #2282550
04/04/17 11:17 PM
04/04/17 11:17 PM
bean town ....Ca
W
W
bean town ....Ca
wave
80lb at 8800
Re: Modified oil pump failure [Re: WHITEDART] #2282552
04/04/17 11:18 PM
04/04/17 11:18 PM
Dillsburg, PA
Dillsburg, PA
Okay. Thought i might be able to help you. I have 6 6.125x2.00x.927.
Howard
Re: Modified oil pump failure [Re: WHITEDART] #2282557
04/04/17 11:23 PM
04/04/17 11:23 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Sorry it happened , but boy were you lucky. You were darn near tossing a rod out the side of the block
Re: Modified oil pump failure [Re: WHITEDART] #2282561
04/04/17 11:29 PM
04/04/17 11:29 PM
bean town ....Ca
W
W
bean town ....Ca
When the motor first went into the car 200 passes ago it did a wheel stand and came down and crushed the oil pan. and hit the pick up.. pretty good.. after a very close inspection I chose to reuse the pump.. and actually shorten the pick up slightly.. so it wouldn't hit the pump.. if it happened again...that was 200 passes ago
Re: Modified oil pump failure [Re: WHITEDART] #2282563
04/04/17 11:30 PM
04/04/17 11:30 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Sure looks like the stud was hitting the pump but maybe Im seeing it wrong
Re: Modified oil pump failure [Re: WHITEDART] #2282568
04/04/17 11:39 PM
04/04/17 11:39 PM
MR_P_BODY Offline
MR_P_BODY  Offline
2 things.. whats the weight oil and what is the
minimum rpm you see 80#
wave
Re: Modified oil pump failure [Re: WHITEDART] #2282584
04/05/17 12:06 AM
04/05/17 12:06 AM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Shiloh, maybe when the pan got crushed it may have fractured the pump & it finally broke off.
Re: Modified oil pump failure [Re: WHITEDART] #2282587
04/05/17 12:17 AM
04/05/17 12:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Looking at it again.. you came down on the pan
and broke it
wave
