62 Polara 500 Cruiser
#1554264
12/27/13 06:56 PM
12/27/13 06:56 PM
Posts: 22,695 Bitopia
jcc
Bitopia
So this car "was" to be the basis for a clone of a 62 Polara I had in HS in the 60's. I bought it sight unseen off ebay in SF. The pics below are on arrival are #1-3. OEM, all Polara's had a 361/4bbl and Alum 727's. This car, according the plethora of receipts that came with it, looked to be owned by a Coors executive in Spokane. He restored it in 1980, and as best I can tell, he replaced motor/trans with a rebuilt slightly warmed over 273/4spd, I assume because this was the middle of the second "gas crisis". This helped in making the car less desirable on ebay, and I didn't care, since I was planning on dropping in a 440+ with long rams. However when I got the car and drove it, plans changed, the 273 was pretty peppy and the car was rather nice, even with the crushed velour interior . So this is just upgrading it into a nice cruiser.
Re: 62 Polara 500 Cruiser
[Re: jcc]
#1554265
12/27/13 06:57 PM
12/27/13 06:57 PM
jcc
Bitopia
2 The wheels are AR 14x8 200S Coke bottles, not my favorite, but I'll keep them as long as they make 245/50's, unfortunately it limits rotor sizes.
[Re: jcc]
#1554266
12/27/13 06:57 PM
12/27/13 06:57 PM
jcc
Bitopia
3 Transport damaged, thought to be as bought but seller said 100% NOT ugh!!!
[Re: jcc]
#1554268
12/27/13 06:59 PM
12/27/13 06:59 PM
jcc
Bitopia
5 Just reminiscing, this is my original custom hood from 1967.
[Re: jcc]
#1554270
12/27/13 07:00 PM
12/27/13 07:00 PM
jcc
Bitopia
7 Period correct wheel? Soon to be replaced by a new one.
[Re: jcc]
#1554271
12/27/13 07:01 PM
12/27/13 07:01 PM
jcc
Bitopia
8 Connector primary flange layout, with center weld hole
[Re: jcc]
#1554272
12/27/13 07:02 PM
12/27/13 07:02 PM
jcc
Bitopia
9 Welded 2x2 connector, not thru the floor
[Re: jcc]
#1554274
12/27/13 07:04 PM
12/27/13 07:04 PM
jcc
Bitopia
11 This was our second set of Flex A Form fiberglass springs, strangely they failed as crack/split indicates, they replaced without hesitation, replacement set was made wrong, likely am using Hyperco only in the future
[Re: jcc]
#1554275
12/27/13 07:04 PM
12/27/13 07:04 PM
jcc
Bitopia
12 Crushed velour? Installing rear seat belts
[Re: jcc]
#1554276
12/27/13 07:05 PM
12/27/13 07:05 PM
jcc
Bitopia
13 Rear seat belt tie down
[Re: jcc]
#1554277
12/27/13 07:06 PM
12/27/13 07:06 PM
jcc
Bitopia
14 One Comp cammed robust 273 with 4 sp out for a little spicing up
[Re: jcc]
#1554279
12/27/13 07:08 PM
12/27/13 07:08 PM
jcc
Bitopia
14.5 I believe the safety loop moves forward with the Passon tranny and losing the slip joint
[Re: jcc]
#1554281
12/27/13 07:10 PM
12/27/13 07:10 PM
jcc
Bitopia
16 If I remember correctly thats a slant six sized 9"? Disc, good for road race?
[Re: jcc]
#1554282
12/27/13 07:11 PM
12/27/13 07:11 PM
jcc
Bitopia
17 New Alum Passon Jamie rocks
