STARTER PROBLEM #2282301
04/04/17 04:23 PM
04/04/17 04:23 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
I got done about a week ago replacing Morpar performance valve covers with new originals,, Took Performance intake off,, cleaned it,, painted it,, Cleaned and touched up the engine with new paint, put it all back together,, finished this about a week ago,,, Went to start it today,, all I got was a clicking noise out of the starter.. I cleaned all the battery terminals, I put a little gas in carb,, it started for a second till the gas ran out,, tried it again,, just a clicking noise,, charged the battery,, same thing,, cleaned the battery ground on the block,, tried it again,,, sparks flew off the POS battery.. no start.. just clicking from starter,, The starter alway worked great,,, But now I"m thinking starter,, wanted any other ideas before I get a new starter.. I worked in a Dodge dealer for 6 years in the 70s. Also tried jumping at starter relay. What's you thoughts? Thanks..
Re: STARTER PROBLEM [Re: JohnH] #2282308
04/04/17 04:30 PM
04/04/17 04:30 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
if you jumped the relay and it still just clicks, did you clean the connections on the starter and verify a solid ground between the starter and the tranny via a test light?
if you did all that then is most likely the starter. i would pull it then and bench test it.
Re: STARTER PROBLEM [Re: JohnH] #2282311
04/04/17 04:32 PM
04/04/17 04:32 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
load test that battery.
make sure the cables are good and not bad at the clamps.
sparks happen because of a bad connection, that means sparks at the battery means a bad connection there.
borrow a battery.
also just because a battery has the proper VOLTS, doesn't mean it has enough AMPS to crank over the engine/starter motor, and the relay will just click. the load tester will tell you about the amps.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: STARTER PROBLEM [Re: JohnH] #2282312
04/04/17 04:32 PM
04/04/17 04:32 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Did you confirm the battery is strong?
If you have a clicking noise at the starter, the relay is good. Try a booster cable from the big positive lug on the starter to the plus on the battery.
Re: STARTER PROBLEM [Re: JohnH] #2282320
04/04/17 04:58 PM
04/04/17 04:58 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Ok... got it fixed,, it was the bolt on the carb return spring that mounts on front of the intake.. not letting the ground wire get full ground off the bolts going thru the intake into the head where I painted the intake.. Took them out,, cleaned the paint off,,, all is well,, Thank you for your input, from the mountains of WV..
Re: STARTER PROBLEM [Re: JohnH] #2282323
04/04/17 05:01 PM
04/04/17 05:01 PM
Andrewh Offline
Andrewh  Offline
turn on the headlights and crank, if they go out you don't have enough amps. or dim very badly.
I have seen bad ground cables cause a no turnover situation as well.
they look fine, but just won't carry the load.
Re: STARTER PROBLEM [Re: JohnH] #2282368
04/04/17 06:07 PM
04/04/17 06:07 PM
if You ain't already, clean that POS cable also that was sparking.
Re: STARTER PROBLEM [Re: JohnH] #2282440
04/04/17 08:48 PM
04/04/17 08:48 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
It's cleaned,,, good to go... thanks all....
