Stroker or Forced induction? #2282174
04/04/17 01:08 PM
04/04/17 01:08 PM
USA
hudsonhornet7x Offline OP
USA
Okay I am in need of some guidance as I am apparently not capable of deciding this on my own lol.
I have the foundation of a 7-800 hp build for my car with Thitek heads, Hellcat block, etc.
I just don't know what I would build. I will say I have always been in love with a high compression lumpy cammed engine, but I have to admit forced induction is cool too.
So, for a older muscle car, help me decide lol!
I will build the rest of the driveline to compliment the engine, and I have no ET goals. Just want a wicked street engine for my B body. One thing I know for sure is if it sounds like a stock engine I will be ticked! LOL.
Thanks!
single choice
Votes accepted starting: 04/04/17 01:07 PM
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2282755
04/05/17 11:51 AM
04/05/17 11:51 AM
USA
USA
Thank you all so far for voting. If anyone has a comment, I am all ears!
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2282757
04/05/17 11:58 AM
04/05/17 11:58 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
I don't have much input except to say that a 6.4 block stroker engine would be wicked as sin. Looking forward to your build whatever you decide...
SuperBeast
An enforcer for the Mopar Mafia!
Re: Stroker or Forced induction? [Re: sycboi] #2282773
04/05/17 12:41 PM
04/05/17 12:41 PM
USA
USA
Steff on this board built a 6.4 stroker with great success. I would be very happy with a build like his.
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2282855
04/05/17 02:49 PM
04/05/17 02:49 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
He definitely has a stout engine. Good luck with yours. It looks fun!
SuperBeast
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2282986
04/05/17 07:29 PM
04/05/17 07:29 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Stroker and your favorite flavor of boost.
My boost choice would be turbo.
Kevin
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2282999
04/05/17 08:01 PM
04/05/17 08:01 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Twin turbo stroker b.b. is in my future.
Go all out.
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2283030
04/05/17 09:18 PM
04/05/17 09:18 PM
ghinmi Offline
ghinmi  Offline
I personally lean towards the turbo side. But if you're looking for a snotty intimidating hot rod motor that's not the right option. Nothing sounds more wicked going down the street than a nasty naturally aspirated motor. It's your build, your choice.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2283331
04/06/17 01:40 PM
04/06/17 01:40 PM
IL
Dart451 Offline
Dart451  Offline
IL
I would lean towards twin screw, just for a more wicked sound. my V10 twin screw makes 720 torque at 2500 rpm. Hard to beat instant torque round town. Max power turbo for the win.
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2283377
04/06/17 03:06 PM
04/06/17 03:06 PM
USA
USA
Okay Gentlemen, I could use some more advice. I currently have a set of manley platinum pistons in the correct bore for this engine. I also have a set of Manley 300m material 6.125 connecting rods. Both of these sets of parts were assembled into a new engine, and then taken out.
I have been told various things about 300m rods. I know they are expensive to buy, but are they a good quality? I have been leaning towards Molnar rods as the crank I will be getting is a Molnar as well, but I thought I could save a few bucks and go with the Manley's.
Here is my math:
9.284 deck height
1.208 compression height pistons
6.125 rods
3.900 crank
410" at zero deck height.
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2283385
04/06/17 03:24 PM
04/06/17 03:24 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Deck height is 9.239.
Re: Stroker or Forced induction? [Re: fbs63] #2283394
04/06/17 03:42 PM
04/06/17 03:42 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
This may be true on the 6.1 blocks but his 6.284 number is correct for 6.4 and Hellcat blocks
Re: Stroker or Forced induction? [Re: GTS340] #2283627
04/06/17 10:58 PM
04/06/17 10:58 PM
IN
ahy Offline
ahy  Offline
IN
I voted stroker based on goals for "personality".
That said, a NA stroker may be more in the 600-650 HP range as a guess. If you need 700+ I think forced induction is needed.
Piston & CR will most likely need to be different for NA vs forced induction. I believe you already have the piston so that may help decide.
Re: Stroker or Forced induction? [Re: ahy] #2283707
04/07/17 12:52 AM
04/07/17 12:52 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Anyone know why they made the deck taller?
Re: Stroker or Forced induction? [Re: fbs63] #2283819
04/07/17 10:23 AM
04/07/17 10:23 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Where do you find that 9.284 dimension? Is this a published spec or an actual physical measurement?
Re: Stroker or Forced induction? [Re: fbs63] #2283829
04/07/17 10:46 AM
04/07/17 10:46 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Dave Webber at Modern Muscle
Re: Stroker or Forced induction? [Re: GTS340] #2283831
04/07/17 10:50 AM
04/07/17 10:50 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Great! Thanks.
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2284101
04/07/17 07:20 PM
04/07/17 07:20 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I voted Procharger because that's what I Have.
A turbo would be how I'd go if it was in an old car.
Stroker don't make enough power when you want to go real fast.
How hard are you going to beat on it?
Re: Stroker or Forced induction? [Re: FastmOp] #2284147
04/07/17 09:17 PM
04/07/17 09:17 PM
USA
USA
I have no ET goals, just want to build something that will run with a Hellcat.
Re: Stroker or Forced induction? [Re: hudsonhornet7x] #2284167
04/07/17 09:58 PM
04/07/17 09:58 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
A 2.9 Whipple will make a 1000 hp, it's fairly affordable, and it's a bolt on, give you plenty of leg to outrun a Hellcat. Turbos make a pile of HP but so does a twin screw. A supercharger would look more at home in a muscle car and give you that snorty, instant throttle response
