Re: Started my turbo build
[Re: moparborn]
#2276440
03/26/17 01:04 PM
03/26/17 01:04 PM
Posts: 3,840 Central Missouri Fort Leonard...
mopar65
Sorry for all the questions. But what brand and size are the turbos?
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: moparborn]
#2278537
03/29/17 10:01 PM
03/29/17 10:01 PM
mopar65
Thanks for the info. I have been looking at some of the GT45 turbos? I like that intercooler.
support our troops
[Re: moparborn]
#2280951
04/02/17 03:58 PM
04/02/17 03:58 PM
mopar65
Damn that's turning out great.
support our troops
[Re: moparborn]
#2304278
05/14/17 01:03 PM
05/14/17 01:03 PM
Posts: 735 Pa. U.S.A.
moparborn
Pa. U.S.A.
Hit the road Saturday, ran good,had to tweek it a little,still will need adjustments. Start up still gives me a little attitude ,have to open throttle a little ,starts up rich,prime set at 50,will keep dropping it. Put about 2 pounds of boost to it,pulled good ( a little smile),then ? ,it started popping and running rough ,i am thinking bad things,get back to the garage,checked it over,relief, two plug wires came loose and melted on the headers,will not let that happen again. Now to find out why the afr goes to 19-23 when letting off the thottle(not under boost),seems a little too lean for comfort.
[Re: moparborn]
#2304295
05/14/17 01:22 PM
05/14/17 01:22 PM
Posts: 700 Phoenix, AZ
MoPwer
Phoenix, AZ
Hit the road Saturday, ran good,had to tweek it a little,still will need adjustments. Start up still gives me a little attitude ,have to open throttle a little ,starts up rich,prime set at 50,will keep dropping it. Put about 2 pounds of boost to it,pulled good ( a little smile),then ? ,it started popping and running rough ,i am thinking bad things,get back to the garage,checked it over,relief, two plug wires came loose and melted on the headers,will not let that happen again. Now to find out why the afr goes to 19-23 when letting off the thottle(not under boost),seems a little too lean for comfort. It should go lean when engine braking above about 1200 or so rpm. The injectors turn off.
-78 Utiline (5.7 Hemi)
