Re: a body 727 to 8 1/4 rear
[Re: maxwedge1]
#2280288
04/01/17 12:42 PM
04/01/17 12:42 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Why not just run a conversion joint on the back Or get a driveshaft from Mancini racing that actually fits as is. http://www.manciniracing.com/driveshafts.html
[Re: maxwedge1]
#2280337
04/01/17 01:54 PM
04/01/17 01:54 PM
Supercuda
About to go away
About to go away
up yours
You can remove and replace the yoke on a 8 1/4, but you need to remember it's a crush sleeve design as well.
Which means you had better reset the preload properly.
[Re: Supercuda]
#2280421
04/01/17 04:37 PM
04/01/17 04:37 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
If you are just going to cruise this car then why bother with a 1350 U-Joint on a 8.25" rear??? Especially with a 416, because the first thing that will break is the 8.25" and when that goes the sprague will roll over in the 727 and you will have parts coming through the floor, but what do I know??
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: maxwedge1]
#2280465
04/01/17 06:14 PM
04/01/17 06:14 PM
RapidRobert
I would get the car up on stands under the rear axle "loaded" & confirm that the bottom of the rear shackles are pointing rearward a bit (can space the front shackles rearward as needed), might as well get it dead on while you are dealing with that area, then butt a yoke into the trans & get a C to C & subtract 5/8-3/4 from that dimention so that you get the correct shaft. Just me I would not mess with the pinion, some solid Neapco or Precision ujoints if needed would likely suffice. confirm that the front yoke moves smoothly thru both planes of travel and the rear ujoint moves smoothly thru its single plane of travel before installing the shaft. OT, a 904 is less rotating mass & is lighter & can be built just as stout.
[Re: maxwedge1]
#2280514
04/01/17 08:08 PM
04/01/17 08:08 PM
Supercuda
About to go away
About to go away
up yours
That's axle shaft spine count, not sure it matters to the pinion yoke.
27 spline in your case, the 29 came out decades later in trucks.
[Re: maxwedge1]
#2280649
04/02/17 12:27 AM
04/02/17 12:27 AM
RapidRobert
my ? is the pinion spline count wich will enable me to order a yoke without first removing the old 1 to count 10 (coarse) or 29 (fine) splines. EDIT I'm thinking if you take off the nut/washer you can count the splines (not sure if that will disturb the preload or not), others will advise on that.
[Re: RapidRobert]
#2280782
04/02/17 11:24 AM
04/02/17 11:24 AM
Supercuda
About to go away
About to go away
up yours
my ? is the pinion spline count wich will enable me to order a yoke without first removing the old 1 to count 10 (coarse) or 29 (fine) splines. EDIT I'm thinking if you take off the nut/washer you can count the splines (not sure if that will disturb the preload or not), others will advise on that. Not applicable to the 8 1/4. Seems they are 27 spline only on the pinion shaft.
[Re: Supercuda]
#2280811
04/02/17 12:03 PM
04/02/17 12:03 PM
RapidRobert
Seems they are 27 spline only on the pinion shaft. My mistake
[Re: maxwedge1]
#2280828
04/02/17 12:29 PM
04/02/17 12:29 PM
Supercuda
About to go away
About to go away
up yours
Not a mistake, a learning experience
