a body 727 to 8 1/4 rear #2280277
04/01/17 12:30 PM
04/01/17 12:30 PM
PA
maxwedge1 Offline OP
PA
76 duster originally 318- 4 spd 8 and 1/4 rear with 7260 u joints.
installing smallblock 727 so shaft needs to be approx. 3" shorter.
want to order a driveshaft. Strange has reasonable price on balanced shaft with 1350 ends.
is my 8 1/4 pinion a 27 spline? i need to get a stronger than stock 7290 or 1350 pinion yoke to match the new shaft.
can i install a new pinion yoke and just re torque ?
Re: a body 727 to 8 1/4 rear [Re: maxwedge1] #2280288
04/01/17 12:42 PM
04/01/17 12:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Why not just run a conversion joint on the back
Or get a driveshaft from Mancini racing that actually fits as is.
http://www.manciniracing.com/driveshafts.html
Don't be the exception.
Re: a body 727 to 8 1/4 rear [Re: maxwedge1] #2280315
04/01/17 01:17 PM
04/01/17 01:17 PM
BDW Offline
BDW  Offline
Very happy with my DS from Mancini
Re: a body 727 to 8 1/4 rear [Re: Supercuda] #2280318
04/01/17 01:32 PM
04/01/17 01:32 PM
PA
PA
i would actually like to upgrade to the larger joint if i can as the motor is a 416 and get rid of the straps and go with u bolts.
Re: a body 727 to 8 1/4 rear [Re: maxwedge1] #2280337
04/01/17 01:54 PM
04/01/17 01:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You can remove and replace the yoke on a 8 1/4, but you need to remember it's a crush sleeve design as well.
Which means you had better reset the preload properly.
Re: a body 727 to 8 1/4 rear [Re: Supercuda] #2280421
04/01/17 04:37 PM
04/01/17 04:37 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
If you are just going to cruise this car then why bother with a 1350 U-Joint on a 8.25" rear??? Especially with a 416, because the first thing that will break is the 8.25" and when that goes the sprague will roll over in the 727 and you will have parts coming through the floor, but what do I know??
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: a body 727 to 8 1/4 rear [Re: maxwedge1] #2280465
04/01/17 06:14 PM
04/01/17 06:14 PM
I would get the car up on stands under the rear axle "loaded" & confirm that the bottom of the rear shackles are pointing rearward a bit (can space the front shackles rearward as needed), might as well get it dead on while you are dealing with that area, then butt a yoke into the trans & get a C to C & subtract 5/8-3/4 from that dimention so that you get the correct shaft. Just me I would not mess with the pinion, some solid Neapco or Precision ujoints if needed would likely suffice. confirm that the front yoke moves smoothly thru both planes of travel and the rear ujoint moves smoothly thru its single plane of travel before installing the shaft. OT, a 904 is less rotating mass & is lighter & can be built just as stout.
Re: a body 727 to 8 1/4 rear [Re: Polarapete] #2280510
04/01/17 07:51 PM
04/01/17 07:51 PM
PA
PA
i intend to visit the track now and then not just cruise.
seems to me running stronger joints are better than smaller ones.
i'm not as concerned about the 8 1/4 as its handled this motor for years.
and the trans has a billet drum and bolt in sprag.
my ? is the pinion spline count wich will enable me to order a yoke without first removing the old 1 to count or finding out after removal there isnt a 7290 or 1350 available. i have seen 27 and 29 spline .
Re: a body 727 to 8 1/4 rear [Re: maxwedge1] #2280514
04/01/17 08:08 PM
04/01/17 08:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That's axle shaft spine count, not sure it matters to the pinion yoke.
27 spline in your case, the 29 came out decades later in trucks.
Re: a body 727 to 8 1/4 rear [Re: maxwedge1] #2280649
04/02/17 12:27 AM
04/02/17 12:27 AM
10 (coarse) or 29 (fine) splines. EDIT I'm thinking if you take off the nut/washer you can count the splines (not sure if that will disturb the preload or not), others will advise on that.
Re: a body 727 to 8 1/4 rear [Re: RapidRobert] #2280782
04/02/17 11:24 AM
04/02/17 11:24 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not applicable to the 8 1/4.
Seems they are 27 spline only on the pinion shaft.
Re: a body 727 to 8 1/4 rear [Re: Supercuda] #2280811
04/02/17 12:03 PM
04/02/17 12:03 PM
My mistake
Re: a body 727 to 8 1/4 rear [Re: maxwedge1] #2280828
04/02/17 12:29 PM
04/02/17 12:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not a mistake, a learning experience
Re: a body 727 to 8 1/4 rear [Re: Supercuda] #2280830
04/02/17 12:32 PM
04/02/17 12:32 PM
Agreed!
