A12 transmission rebuild/resto? #228015
02/17/09 07:51 PM
02/17/09 07:51 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Should I add the later model part throttle kickdown assembly onto the valve body when I get it rebuilt?
Any other minor mods that I should do?
Re: A12 transmission rebuild/resto? [Re: cdp] #228016
02/17/09 09:04 PM
02/17/09 09:04 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Here are a few things to consider, especially if you have some oats under the hood:
-Set of Alto reds and Kolene steels.
-Lube modded pump stator,
-Solid front band.
-Bolt in sprag- Ultimate is nice here.
-Updated Belleville spring in the fwd. clutch drum.
- DO NOT INSTALL THE 5.0 or 4.2 lever if you are running bias tires, stick with a 2.8 or 3.2.
-Get a Transgo shift kit and follow the instructions for the level of performance desired. PT kickdown module is nice. You may consider buying a done V/B from Cope or Allison if you don't feel like doing the mods yourself.
-MP deep pan or 518 pan with molded reusable gasket.
Some of this stuff may be overkill, as I know nothing of the engine build, so take that for what it's worth.
MB
Re: A12 transmission rebuild/resto? [Re: HPMike] #228017
02/17/09 09:35 PM
02/17/09 09:35 PM
Connecticut
5126brl No more Offline
Connecticut
Hey Mike, Please clean out your mail box.
Re: A12 transmission rebuild/resto? [Re: 5126brl No more] #228018
02/17/09 09:40 PM
02/17/09 09:40 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Its a stock motor. .030 over., balanced, Mr Sixpack cam, 9.5 compression, stock exh, 4:10's. It will be a resto-trailer queen 90% of the time. All #'s matching.
But I would like to see a few high 12's if possible.
Re: A12 transmission rebuild/resto? [Re: HPMike] #228019
02/17/09 11:34 PM
02/17/09 11:34 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
-Solid front band.
MB
How much extra trans fluid does the deep MP pan hold?
Re: A12 transmission rebuild/resto? [Re: RoadRunnerJD] #228020
02/18/09 10:35 AM
02/18/09 10:35 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
-Solid front band.
MB
At least 2 , maybe 3 ? You need to add a spacer though to make use of it .
