Re: A12 transmission rebuild/resto?
[Re: HPMike]
#228019
02/17/09 11:34 PM
02/17/09 11:34 PM
Posts: 5,123 Warrenton, VA
RoadRunnerJD
Warrenton, VA
Here are a few things to consider, especially if you have some oats under the hood:
-Set of Alto reds and Kolene steels. -Lube modded pump stator, -Solid front band. -Bolt in sprag- Ultimate is nice here. -Updated Belleville spring in the fwd. clutch drum. - DO NOT INSTALL THE 5.0 or 4.2 lever if you are running bias tires, stick with a 2.8 or 3.2. -Get a Transgo shift kit and follow the instructions for the level of performance desired. PT kickdown module is nice. You may consider buying a done V/B from Cope or Allison if you don't feel like doing the mods yourself. -MP deep pan or 518 pan with molded reusable gasket.
Some of this stuff may be overkill, as I know nothing of the engine build, so take that for what it's worth.
MB
How much extra trans fluid does the deep MP pan hold?
[Re: RoadRunnerJD]
#228020
02/18/09 10:35 AM
02/18/09 10:35 AM
Posts: 74,990 U.S.S.A.
JohnRR
U.S.S.A.
MB
At least 2 , maybe 3 ? You need to add a spacer though to make use of it .
