foam seal for Strato Vent upper duct #2279381
03/31/17 09:14 AM
03/31/17 09:14 AM
Ottawa, Ontario
L.R Helbling Offline OP
Ottawa, Ontario
Would anybody be able to share a pic of an original seal (if there ever was one) in the metal flange between the heater box and the upper transfer duct to a 71 b body Plymouth? I would like to know how thick and how wide to cut the seal before installing the duct to the strato vent. Thanks
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279619
03/31/17 03:28 PM
03/31/17 03:28 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
My original was Mia
I got a replacement seal from DMT
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279621
03/31/17 03:32 PM
03/31/17 03:32 PM
Ottawa, Ontario
Ottawa, Ontario
Thanks flypaper. I know the feeling. I ordered up a kit from DMT for my car. Every seal, gasket and rope caulking was included except that one. I will post a pic soon to illustrate the flange that I`m talking about. Maybe that will help.
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279634
03/31/17 03:43 PM
03/31/17 03:43 PM
Ottawa, Ontario
Ottawa, Ontario
It's the rectangular looking flange with a tab for a sheet metal screw in front of the strato vent vacuum actuator. Of course, I could make something but would like to see how the original is cut and installed to reduce leakage at that point.
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279635
03/31/17 03:48 PM
03/31/17 03:48 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
The strato seals are a separate kit
I bought my kit from him at a show
And he didn't have the strato kit in stock
So he sent to me later it in the mail
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279640
03/31/17 03:56 PM
03/31/17 03:56 PM
Ottawa, Ontario
Ottawa, Ontario
Weird. My kit came with all of the strato vent seals and gaskets except that one. It's no bother. I could make something up, but would need dimensions; how thick, what material, inside edges go where? I'll take a stab at it tonight.
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279688
03/31/17 05:09 PM
03/31/17 05:09 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Can you take pictures of where the other 3 Stratovent foams that are in the kit go? I thought thats all there were. I can laser cut that one for you today and drop in the mail if you give me some dimensions.
Jim Fillmore
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279732
03/31/17 06:24 PM
03/31/17 06:24 PM
Ottawa, Ontario
Ottawa, Ontario
There you go Jim. I'll get you those measurements in a bit. Thanks. Lou
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279737
03/31/17 06:36 PM
03/31/17 06:36 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Super!
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279738
03/31/17 06:37 PM
03/31/17 06:37 PM
Ottawa, Ontario
Ottawa, Ontario
Outside: 5-1/8" X 4-3/16"
Inside: 3-13/16" X 2-7/8"
Thanks Jim
Lou
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279778
03/31/17 07:33 PM
03/31/17 07:33 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
I'm doing 2 71 heater boxes at the moment also ..
i just tore 3 heater boxes down,1 now for parts
and haven't had the chance to blast a few things
before i start to put them back together.
so i haven't really checked where all the seals go yet.
when i took my strato box apart it was filled up with acorns
and the heater motor wheel had a big chunk chewed out of it by some damn rodents..
i'm so glad i did not sell off a spare heater box i have
that is now being raped for parts.
i look at the extra kit i have and it appears that seal is in there.
i will find out when i cross that bridge.
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279807
03/31/17 08:22 PM
03/31/17 08:22 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Hey Lou,
Does it need that tab and screw hole in it? If so shoot me the dimensions for that too.
Re: foam seal for Strato Vent upper duct [Re: 71TA] #2279819
03/31/17 08:33 PM
03/31/17 08:33 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
The box looks SPECTACULAR.
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279822
03/31/17 08:35 PM
03/31/17 08:35 PM
Ottawa, Ontario
Ottawa, Ontario
In my opinion, no. if you were to foam that tab and screw hole, it would be more of a hindrance than an asset.
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279825
03/31/17 08:36 PM
03/31/17 08:36 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
PM me your address then
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279826
03/31/17 08:36 PM
03/31/17 08:36 PM
Ottawa, Ontario
Ottawa, Ontario
Wow! that was fast! and thanks for the compliment!
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279827
03/31/17 08:37 PM
03/31/17 08:37 PM
Ottawa, Ontario
Ottawa, Ontario
ok coming up.
Re: foam seal for Strato Vent upper duct [Re: L.R Helbling] #2279828
03/31/17 08:44 PM
03/31/17 08:44 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I've been using CAD programming industrial machines, robots, servos, lasers, CNC , vinyl cutters for 30 years. Technology is cool and fast.
My newest toy I mean tool. 54" tangential knife vinyl cutter. It steers the knife thru the cut instead of dragging it like inexpensive cutters and is lightning fast.
(Excuse the mess in the background)
Re: foam seal for Strato Vent upper duct [Re: flypaper] #2279829
03/31/17 08:45 PM
03/31/17 08:45 PM
Ottawa, Ontario
Ottawa, Ontario
The little parts on these boxes are becoming more and more scarce to find. Don't throw anything away. if it looks like a twisted piece of useless metal, it's probably the correct shaft for your strato vent door.
Re: foam seal for Strato Vent upper duct [Re: 71TA] #2279830
03/31/17 08:47 PM
03/31/17 08:47 PM
Ottawa, Ontario
Ottawa, Ontario
Oh man! I am seeing it and I am liking it!
