Fresh Air Vent Door Seal (66 Coronet) #2278253
03/29/17 11:52 AM
03/29/17 11:52 AM
Mountain View, CA
68rrunner Offline OP
Mountain View, CA
So a rat seems to have decided it REALLY wanted in and chewed off half of the rubber seal on the internal "blade" to the vent. Anyone have a line on these for a 66 Coronet? Doesn't seem like anyone makes one and the seal design would be tough to duplicate. I'd prefer to not block it off.
Re: Fresh Air Vent Door Seal (66 Coronet) [Re: 68rrunner] #2278265
03/29/17 12:17 PM
03/29/17 12:17 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
Not sure if your vent is integral to the heater box or not but here is a good place to check for foam and rubber seals.
http://www.detroitmuscletechnologies.com/62-65-b-body-heater-box/
Re: Fresh Air Vent Door Seal (66 Coronet) [Re: 68rrunner] #2278758
03/30/17 10:05 AM
03/30/17 10:05 AM
Mountain View, CA
Mountain View, CA
It is the one on the inside.
We were able to find a whole assembly for sale, hopefully it's in good shape.
Re: Fresh Air Vent Door Seal (66 Coronet) [Re: 68rrunner] #2278823
03/30/17 12:32 PM
03/30/17 12:32 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
Those black rubber seals on the 66-70 and 71-74 B body (and E body) fresh air vent doors is "over-molded" onto the steel door. It's not replaceable. I get so many requests for these seals that I buy a dozen or so of these vents every year when I'm at the shows so I can help customers looking for them. 1/2 the ones I get are usually pulled away/delaminated from the steel but they can usually be glued back down. It's pretty rare that they are destroyed or "eaten by rodents".
That must have been you that I sold the vent to yesterday. Small Mopar world. Glad I could help. For chap the vent may not have been pristine but the door was the best one I had.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Fresh Air Vent Door Seal (66 Coronet) [Re: 68rrunner] #2279727
03/31/17 06:17 PM
03/31/17 06:17 PM
Mountain View, CA
Mountain View, CA
That's us. Thanks for the help.
