EDELBROCK E STREET HEADS FOR 383 #2277607
03/28/17 11:00 AM
03/28/17 11:00 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
ARE THESE GOOD FOR A HI PO STREET ENG,ARE THEY CLOSED OR OPEN CHAMBER HEADS.
Re: EDELBROCK E STREET HEADS FOR 383 [Re: moparpro] #2277622
03/28/17 11:48 AM
03/28/17 11:48 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
5090 is 75CC, 5093 is 84cc chamber size.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: EDELBROCK E STREET HEADS FOR 383 [Re: moparpro] #2277631
03/28/17 12:02 PM
03/28/17 12:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes they are closed chamber
Re: EDELBROCK E STREET HEADS FOR 383 [Re: moparpro] #2277656
03/28/17 12:51 PM
03/28/17 12:51 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Be sure your headers are angle plug friendly.
For exhaust manifolds, straight plugs are "preferred"(as in Stealth heads).
Re: EDELBROCK E STREET HEADS FOR 383 [Re: moparpro] #2277709
03/28/17 02:21 PM
03/28/17 02:21 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I ordered the 5090 , Fel Pro Gaskets and APR head bolts
Plan on running factory exhaust manifolds , factory valve covers and rocker arms , along with a Performer Rpm and either a Factory Carter Avs or a Edelbrock Avs on my 71 Bee
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: EDELBROCK E STREET HEADS FOR 383 [Re: bee1971] #2278040
03/28/17 10:47 PM
03/28/17 10:47 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
any distributor vaccum cannister clearence problems.
Re: EDELBROCK E STREET HEADS FOR 383 [Re: moparpro] #2292588
04/23/17 10:16 AM
04/23/17 10:16 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Zero issues with factory distributor and vacuum advance
Found this
NOTE: This head will need to be machined for clearance if used with a MSD Ready to Run distributor.
Need a question answered
I noticed the intake manifold bolt threads are open on these heads, drilled through
Should i use a sealant on my ARP Intake Bolts like Hylomar or Anti-Seize or ?
Dont want any oil puddles on valley pan
Also the Edelbrock / Fel Pro Blue Perma Torque Head Gaskets should bee installed dry correct ? And looking at these gaskets it shouldnt matter what side is up or down
Thanx Scott
Siberian Huskies
Re: EDELBROCK E STREET HEADS FOR 383 [Re: bee1971] #2293236
04/24/17 02:25 PM
04/24/17 02:25 PM
dogdays Offline
dogdays  Offline
Yes it makes sense to install bolts with a little sealer. Lots of different stuff will work, including good ol' Permatex. Hylomar for sure will work.
NO MATTER what others will say, those gaskets are designed to go on a clean surface, dry. All the sealing goop they need is already there on the surface of the gaskets. We aren't gasket experts (except Roadhazard). That's why they make the gaskets and we just buy them. On gaskets that do not have dowels to hold them in place I sometimes use small dabs of Hi-Tack to stick them in place.
IMHO those heads are THE heads for a mostly stock 383.
R.
Re: EDELBROCK E STREET HEADS FOR 383 [Re: moparpro] #2293587
04/25/17 12:20 AM
04/25/17 12:20 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Perfect
Thanx
Gaskets installed dry , and torqued to 70 foot pounds after two trips to Sears and there wonderful micro click 1/2" torque wrench that was a week out of warranty
Finally found someone (Took a young man who knew exactly what ratchet kit was needed after three older guys didn't have a clue) who could rebuild the ratchet head for me , even offered to pay for the kit , thru him some cash
Should of just stole a torque wrench from work
Anyways a lot of paint work and detailing before wrapping things up
Siberian Huskies
Re: EDELBROCK E STREET HEADS FOR 383 [Re: bee1971] #2293851
04/25/17 02:08 PM
04/25/17 02:08 PM
dogdays Offline
dogdays  Offline
Got you beat.....My first torque wrench is a Montgomery Ward and the ratchet head is messed up.
Got it for my 15th or 16th birthday. My mother asked what I wanted and I told her, torque wrench. It was and still is the single best present I've ever received.
I went on a rampage a few years ago and bought a bunch of Snap-On dial torque wrenches. They are really nice for doing more precise work, and as you're sneaking up on maximum torque and the bolt starts to give (yield) it is pretty obvious. But the micro click torque wrendh is my favorite for reassembly in a hurry or in tight spots.
R.
Re: EDELBROCK E STREET HEADS FOR 383 [Re: dogdays] #2293958
04/25/17 04:49 PM
04/25/17 04:49 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
Now you guys have me worried. I installed my fel pro head gaskets for my trick flow heads with a coat of copper spray on each side.
Re: EDELBROCK E STREET HEADS FOR 383 [Re: JoesMopar] #2294082
04/25/17 08:54 PM
04/25/17 08:54 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Lots of people do that. It isn't necessary and I doubt it will cause any harm.
You're clamping the load down so hard it likely won't move unless you seriously abuse it.
- Stu Harmon
Re: EDELBROCK E STREET HEADS FOR 383 [Re: feets] #2294544
04/26/17 03:58 PM
04/26/17 03:58 PM
dogdays Offline
dogdays  Offline
Yes, it's better not to do it according to the gasket manufacturers but as you have already done it, no way would I take that engine apart again.
Put some miles on it!
Worry about something more important, like, will there be a "Dukes of Hazzard II" and who plays Daisy.
R.
PS: Speaking of Dukes of Hazzard, just try to imagine the show performed with a 2017 Charger. Boom goes the airbag as they land from the first jump.
Re: EDELBROCK E STREET HEADS FOR 383 [Re: JoesMopar] #2294606
04/26/17 06:28 PM
04/26/17 06:28 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Steel shim or composite/fiber? If composite/fiber WHY ????
No need to answer haha
Re: EDELBROCK E STREET HEADS FOR 383 [Re: moparpro] #2296078
04/29/17 01:39 PM
04/29/17 01:39 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Factory Valve Covers
Edit Post
Siberian Huskies
Re: EDELBROCK E STREET HEADS FOR 383 [Re: moparpro] #2300386
05/06/17 11:14 PM
05/06/17 11:14 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Help
Been driving the car the last few days
Ran awesome until this aft , really like flipping a switch
Anyways history on the motor , engine was rebuilt about ten years ago , zero issues with motor , Speed Pro forged aluminum pistons .030 over - Mopar 284 - 484 cam set straight up
Motor ran flawless
Edelbrock intake - Carter AVS carb - Factory HP Manifolds
906 heads that had all the machine work done when engine was rebuilt
Anyways
Before installing these heads , I checked pistons where .027 in the hole , used the .038 Fel Pro Blue Head Gaskets from Edelbrock
Everything torqued proper
Car ran great the last few days
Coming home today after a cruise noticed a slight lifter or rocker arm tick at the gas station
Literally a mile from the house it let loose , I knew exactly what it was
Pulled the valve covers and the #4 cylinder - Intake valve pushrod had turned into a pretzel
Every other pushrod was perfect on all cylinders - New pushrods and factory shafts / rockers when engine was rebuilt years ago
Everything was kept the same except these new E Street Heads 75 cc
Installed the supplied rocker arm shaft studs supplied with the heads
Used all the factory valvetrain etc. everything looked great and was torqued down
Rocker arm shafts oil holes down and offset towards valves
What the hell Just happened , I am speechless
I would imagine i will have to pull the intake and pan to check the lifter and cam , correct ?
Do I have to pull these damn heads again ?
Motor never saw over 5500 Rpms the last few days just like the last ten years
Thanx Scott
Siberian Huskies
Re: EDELBROCK E STREET HEADS FOR 383 [Re: bee1971] #2300405
05/06/17 11:37 PM
05/06/17 11:37 PM
V/P contact might be a possibility. If you have a borescope you could go in the plug hole & see. A valve might have been too tight in the guide & seized up.
Re: EDELBROCK E STREET HEADS FOR 383 [Re: RapidRobert] #2300449
05/07/17 12:28 AM
05/07/17 12:28 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
I can steal a borescope from work on Monday
This sucks with a car show tomorrow and mostly sunny
Been working on this damn thing like forever when any free time from work
Siberian Huskies
Re: EDELBROCK E STREET HEADS FOR 383 [Re: moparpro] #2300584
05/07/17 11:09 AM
05/07/17 11:09 AM
Idaho
LaRoy Engines Offline
Idaho
Did you install the heads OOTB?
Re: EDELBROCK E STREET HEADS FOR 383 [Re: moparpro] #2300600
05/07/17 11:35 AM
05/07/17 11:35 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
coil bind on the spring? is it too much lift for the springs?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
