Re: EDELBROCK E STREET HEADS FOR 383
[Re: moparpro]
#2277622
03/28/17 11:48 AM
03/28/17 11:48 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
5090 is 75CC, 5093 is 84cc chamber size.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: moparpro]
#2277631
03/28/17 12:02 PM
03/28/17 12:02 PM
Posts: 74,904 U.S.S.A.
JohnRR
U.S.S.A.
Yes they are closed chamber
[Re: moparpro]
#2277656
03/28/17 12:51 PM
03/28/17 12:51 PM
Posts: 14,478 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Be sure your headers are angle plug friendly.
For exhaust manifolds, straight plugs are "preferred"(as in Stealth heads).
[Re: moparpro]
#2277709
03/28/17 02:21 PM
03/28/17 02:21 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
I ordered the 5090 , Fel Pro Gaskets and APR head bolts
Plan on running factory exhaust manifolds , factory valve covers and rocker arms , along with a Performer Rpm and either a Factory Carter Avs or a Edelbrock Avs on my 71 Bee
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: moparpro]
#2292588
04/23/17 10:16 AM
04/23/17 10:16 AM
bee1971
Sobieski Wi
Zero issues with factory distributor and vacuum advance
Found this
NOTE: This head will need to be machined for clearance if used with a MSD Ready to Run distributor.
Need a question answered
I noticed the intake manifold bolt threads are open on these heads, drilled through
Should i use a sealant on my ARP Intake Bolts like Hylomar or Anti-Seize or ?
Dont want any oil puddles on valley pan
Also the Edelbrock / Fel Pro Blue Perma Torque Head Gaskets should bee installed dry correct ? And looking at these gaskets it shouldnt matter what side is up or down
Thanx Scott
[Re: moparpro]
#2293587
04/25/17 12:20 AM
04/25/17 12:20 AM
bee1971
Sobieski Wi
Perfect
Thanx
Gaskets installed dry , and torqued to 70 foot pounds after two trips to Sears and there wonderful micro click 1/2" torque wrench that was a week out of warranty
Finally found someone (Took a young man who knew exactly what ratchet kit was needed after three older guys didn't have a clue) who could rebuild the ratchet head for me , even offered to pay for the kit , thru him some cash
Should of just stole a torque wrench from work
Anyways a lot of paint work and detailing before wrapping things up
[Re: bee1971]
#2293851
04/25/17 02:08 PM
04/25/17 02:08 PM
dogdays
Got you beat.....My first torque wrench is a Montgomery Ward and the ratchet head is messed up.
Got it for my 15th or 16th birthday. My mother asked what I wanted and I told her, torque wrench. It was and still is the single best present I've ever received.
I went on a rampage a few years ago and bought a bunch of Snap-On dial torque wrenches. They are really nice for doing more precise work, and as you're sneaking up on maximum torque and the bolt starts to give (yield) it is pretty obvious. But the micro click torque wrendh is my favorite for reassembly in a hurry or in tight spots.
R.
[Re: JoesMopar]
#2294082
04/25/17 08:54 PM
04/25/17 08:54 PM
Posts: 28,063 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Now you guys have me worried. I installed my fel pro head gaskets for my trick flow heads with a coat of copper spray on each side. Lots of people do that. It isn't necessary and I doubt it will cause any harm. You're clamping the load down so hard it likely won't move unless you seriously abuse it.
[Re: JoesMopar]
#2294606
04/26/17 06:28 PM
04/26/17 06:28 PM
JohnRR
U.S.S.A.
Now you guys have me worried. I installed my fel pro head gaskets for my trick flow heads with a coat of copper spray on each side. Steel shim or composite/fiber? If composite/fiber WHY ???? No need to answer
[Re: moparpro]
#2296078
04/29/17 01:39 PM
04/29/17 01:39 PM
bee1971
Sobieski Wi
Factory Valve Covers
Edit Post
[Re: moparpro]
#2300386
05/06/17 11:14 PM
05/06/17 11:14 PM
bee1971
Sobieski Wi
Help
Been driving the car the last few days
Ran awesome until this aft , really like flipping a switch
Anyways history on the motor , engine was rebuilt about ten years ago , zero issues with motor , Speed Pro forged aluminum pistons .030 over - Mopar 284 - 484 cam set straight up Motor ran flawless Edelbrock intake - Carter AVS carb - Factory HP Manifolds 906 heads that had all the machine work done when engine was rebuilt
Anyways
Before installing these heads , I checked pistons where .027 in the hole , used the .038 Fel Pro Blue Head Gaskets from Edelbrock
Everything torqued proper Car ran great the last few days Coming home today after a cruise noticed a slight lifter or rocker arm tick at the gas station
Literally a mile from the house it let loose , I knew exactly what it was
Pulled the valve covers and the #4 cylinder - Intake valve pushrod had turned into a pretzel
Every other pushrod was perfect on all cylinders - New pushrods and factory shafts / rockers when engine was rebuilt years ago
Everything was kept the same except these new E Street Heads 75 cc Installed the supplied rocker arm shaft studs supplied with the heads Used all the factory valvetrain etc. everything looked great and was torqued down Rocker arm shafts oil holes down and offset towards valves
What the hell Just happened , I am speechless
I would imagine i will have to pull the intake and pan to check the lifter and cam , correct ?
Do I have to pull these damn heads again ?
Motor never saw over 5500 Rpms the last few days just like the last ten years
Thanx Scott
[Re: bee1971]
#2300405
05/06/17 11:37 PM
05/06/17 11:37 PM
RapidRobert
V/P contact might be a possibility. If you have a borescope you could go in the plug hole & see. A valve might have been too tight in the guide & seized up.
[Re: RapidRobert]
#2300449
05/07/17 12:28 AM
05/07/17 12:28 AM
bee1971
Sobieski Wi
V/P contact might be a possibility. If you have a borescope you could go in the plug hole & see. A valve might have been too tight in the guide & seized up. I can steal a borescope from work on Monday This sucks with a car show tomorrow and mostly sunny Been working on this damn thing like forever when any free time from work
