1961 Plymouth Fury disc brake conversion #2277410
03/27/17 10:52 PM
03/27/17 10:52 PM
Tampa Florida
missile fan Offline OP
Tampa Florida
I have a 1961 Plymouth Fury ( c body)
I am looking for a kit to convert the front brakes to disc
and a modern power brake booster with a dual reservoir master cyl
Re: 1961 Plymouth Fury disc brake conversion [Re: missile fan] #2277469
03/28/17 12:44 AM
03/28/17 12:44 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Scarebird offers the disc conversion caliper brackets.
https://scarebird.com/index.php?route=product/product&path=64&product_id=54
Re: 1961 Plymouth Fury disc brake conversion [Re: missile fan] #2285822
04/11/17 01:54 PM
04/11/17 01:54 PM
Peoples Republic of Oregon
W
wayfarer Offline
wayfarer  Offline
W
Send a note to George at geomr2001@yahoo.com
I believe that he used all oem parts on his 60 Ply.
FWIW, he is in Ft Walton Beach area.
www.qualityengineeredcomponents.com
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
***inventory clearance in progress. Nothing held back. See website.***
Re: 1961 Plymouth Fury disc brake conversion [Re: missile fan] #2286850
04/13/17 03:56 AM
04/13/17 03:56 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I think FMJ spindles can be coaxed into service on that platform.
Check with therocks. I think his son had a 62 Chrysler that they used them on. Should be the same front end IIRC.
And just for the record C-bodies didn't start until 1965. biggrin
Kevin
Re: 1961 Plymouth Fury disc brake conversion [Re: Twostick] #2286930
04/13/17 10:41 AM
04/13/17 10:41 AM
moparx Online content
moparx  Online Content
the 57-61 fury uses the K772 upper ball joint and the K719 [screw in] lower joint on all models. the lower joint has the same taper as the 74&up B body spindles [which also uses the K719 screw in lower joint] with the steering arm having the taper in the steering arm instead of the lower control arm. so score a late set of spindles [F,M,J body], caliper brackets of your rotor diameter choice, and the steering arms. the tie rod tapers are the same also. you may be able to use your existing steering arms, but i forget if that's possible. the only other thing you need to do is shorten [i think] the tie rod adjuster sleeves to get the proper toe adjustment. and if i also remember correctly [at my age, the "remembering correctly" statement is, um, kinda related to "oldtimers" biggrin], your original spindle is the same height, or real close to, the late model "tall" spindle some guys are afraid to use in their A and B body conversions. hope this is of some help to you.
beer
Re: 1961 Plymouth Fury disc brake conversion [Re: missile fan] #2286935
04/13/17 10:54 AM
04/13/17 10:54 AM
AZ
Mike P Offline
Mike P  Offline
AZ
I was doing a lot of disc brake conversions on the 57-61s years ago. 70s A Body spindles, rotors and calipers can be made to work fairly easily but require modifying the tie rod and tie rod sleeve and steering stops. 77-78 C Body spindles, rotors, and calipers will also work but in addition to the tie rod/steering stop modifications also require a modification to the spindle and selecting the correct ball joints. The geometry of the A and C body spindles is not an exact match to the original spindles which will require an alignment afterword and you end up with a little bit quicker steering.
I think AAJ was about the first outfit to offer a conversion using the stock spindles. I have that conversion on my 57 Plymouth and would use it again if I were building another car of this era. As I recall they use A Body rotors and I believe GM Calipers.
http://www.aajbrakes.com/rproductinfo.html
I haven't used the Scarebird stuff, but have heard good things about them and you do end up with bigger rotors. With AAJ or Scarebird you end up with a lot less work (and if you car is correctly aligned save a trip to the alignment shop).
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 1961 Plymouth Fury disc brake conversion [Re: missile fan] #2289539
04/17/17 05:22 PM
04/17/17 05:22 PM
Colorado springs, CO
Arominus Offline
Arominus  Offline
Get the Scarebird kit and don't look back, no spindle mods, no oddball geometry curves from running a newer spindle, just a solid bolt in.
Your other good options are from SSBC or magnumforce sells a wilwood kit for a hefty premium (double what the 60's era stuff sells for).
1957 Desoto Firesweep 2dr
392/A518 builds in progress.
