1969 B body rear assembly problems HELP
#2275912
03/25/17 12:23 PM
03/25/17 12:23 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
8 3/4 3.55 - assembly - left axle has about 1/8 play - do both axles have a button on the end ? this one doesn't and I cant remember how it came out - or did I do something else wrong - any help?
68 Satellite Wagon and a few other ones
Re: 1969 B body rear assembly problems HELP
[Re: mro]
#2275919
03/25/17 12:31 PM
03/25/17 12:31 PM
RapidRobert
The suregrip has the 2 buttons connected with a roll pin. A non sure grip pig would have the round shiney "flats" that the axle ends butt against.
[Re: mro]
#2275935
03/25/17 12:52 PM
03/25/17 12:52 PM
mro
Lynch Road
So did I put the wrong axles with the suregrip or is the problem in the suregrip itself ? The right side fit right ? are there any diagrams you know of this showing what I need to do
[Re: mro]
#2275955
03/25/17 01:27 PM
03/25/17 01:27 PM
RapidRobert
You can swap sure grip & non sure grip pigs & nothing changes on the axles so it would have to be non axle related. I would look in & see if the button is there on the offending side. You are adjusting the threaded collar on the one axle & still not enough? EDIT I've seen two different thicknesses of the white foam gasket that goes between the axle flange and the b plate, the eBay ones ($9.95 for 2 foam/2 steel iirc) are a weak 3/16" thick & iirc the felpro ones are much thinner (I cant find em at the moment).
[Re: mro]
#2275968
03/25/17 01:53 PM
03/25/17 01:53 PM
mro
Lynch Road
The axle that isn't sitting right has no buttone - just the end of the axle with a small hole
[Re: mro]
#2275974
03/25/17 01:57 PM
03/25/17 01:57 PM
RapidRobert
looking in, there is no button on the pig?
[Re: mro]
#2276006
03/25/17 02:55 PM
03/25/17 02:55 PM
mro
Lynch Road
Ill check - should there be a little plate on the tip of the axle?
[Re: mro]
#2276016
03/25/17 03:10 PM
03/25/17 03:10 PM
RapidRobert
nothing on the splined tip of the axle, it is cutoff square with a slight chamfering around the perimeter, just the shallow hole in the center for when they chucked it up in the lathe to machine the shaft.
[Re: mro]
#2276021
03/25/17 03:16 PM
03/25/17 03:16 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
What case is the center section, 742, 489? 489 would have a piece in there, open or sure grip, but a 742 has the button as mention that will come out.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: mro]
#2276220
03/25/17 11:04 PM
03/25/17 11:04 PM
mro
Lynch Road
Is there any chance the button fell off and is floating around ?
[Re: Silver70]
#2276227
03/25/17 11:17 PM
03/25/17 11:17 PM
Posts: 784 Florida
cbusters
What case is the center section, 742, 489? 489 would have a piece in there, open or sure grip, but a 742 has the button as mention that will come out. A clutch type center would fit in many different carrier housings. I have had a early clutch type in a 489 case, so that is not a guide. The OP needs to look or have sometime "in the know" look and figure out if there is something missing. We are assuming there is an adjuster on one axle. We are assuming there are still tapered bearings on the axles. We are assuming the installed axle is seated. Too many variables right now.
[Re: cbusters]
#2276507
03/26/17 02:34 PM
03/26/17 02:34 PM
Silver70
Rust Belt, SW PA
What case is the center section, 742, 489? 489 would have a piece in there, open or sure grip, but a 742 has the button as mention that will come out. A clutch type center would fit in many different carrier housings. I have had a early clutch type in a 489 case, so that is not a guide. The OP needs to look or have sometime "in the know" look and figure out if there is something missing. We are assuming there is an adjuster on one axle. We are assuming there are still tapered bearings on the axles. We are assuming the installed axle is seated. Too many variables right now. True but it's a good start to figure out the issue... It would be the first thing I would check.
[Re: mro]
#2277105
03/27/17 12:42 PM
03/27/17 12:42 PM
mro
Lynch Road
May have found the problem - one axle is 1/4 shorter then the other - buttons are in place - the axles should be the same height right? They must have got mixed up in storage
[Re: mro]
#2277112
03/27/17 12:49 PM
03/27/17 12:49 PM
mro
Lynch Road
scratch that - they are both 29 1/4
[Re: mro]
#2277114
03/27/17 12:51 PM
03/27/17 12:51 PM
RapidRobert
I wouldn't think there is another app that has axles that close to B body dimentions. compare the bearing/adjuster plate, the items at the outer end of the axles, their spacing on the axle & see if you see any discrepency. are you using the thick or the thin white foam seals? If I can find my thin felpros' I will measure them compared to the thick eBay ones I (also) have.
[Re: mro]
#2277162
03/27/17 02:26 PM
03/27/17 02:26 PM
mro
Lynch Road
I talked with the guy working on this and he said when he adjusts the right side it has no effect on the left
[Re: mro]
#2277163
03/27/17 02:27 PM
03/27/17 02:27 PM
mro
Lynch Road
- axles 29 1/4, buttons in place, 489 case, any ideas ?
