1969 B body rear assembly problems HELP #2275912
03/25/17 12:23 PM
03/25/17 12:23 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
8 3/4 3.55 - assembly - left axle has about 1/8 play - do both axles have a button on the end ? this one doesn't and I cant remember how it came out - or did I do something else wrong - any help?
68 Satellite Wagon and a few other ones
Re: 1969 B body rear assembly problems HELP [Re: mro] #2275919
03/25/17 12:31 PM
03/25/17 12:31 PM
The suregrip has the 2 buttons connected with a roll pin. A non sure grip pig would have the round shiney "flats" that the axle ends butt against.
Re: 1969 B body rear assembly problems HELP [Re: mro] #2275935
03/25/17 12:52 PM
03/25/17 12:52 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
So did I put the wrong axles with the suregrip or is the problem in the suregrip itself ? The right side fit right ? are there any diagrams you know of this showing what I need to do
Re: 1969 B body rear assembly problems HELP [Re: mro] #2275955
03/25/17 01:27 PM
03/25/17 01:27 PM
You can swap sure grip & non sure grip pigs & nothing changes on the axles so it would have to be non axle related. I would look in & see if the button is there on the offending side. You are adjusting the threaded collar on the one axle & still not enough? EDIT I've seen two different thicknesses of the white foam gasket that goes between the axle flange and the b plate, the eBay ones ($9.95 for 2 foam/2 steel iirc) are a weak 3/16" thick & iirc the felpro ones are much thinner (I cant find em at the moment).
Re: 1969 B body rear assembly problems HELP [Re: mro] #2275968
03/25/17 01:53 PM
03/25/17 01:53 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
The axle that isn't sitting right has no buttone - just the end of the axle with a small hole
Re: 1969 B body rear assembly problems HELP [Re: mro] #2275974
03/25/17 01:57 PM
03/25/17 01:57 PM
looking in, there is no button on the pig?
Re: 1969 B body rear assembly problems HELP [Re: mro] #2275976
03/25/17 01:58 PM
03/25/17 01:58 PM
cbusters Offline
cbusters  Offline
The "button" is in the carrier. You will need to use a flashlight and look into the spot the axle spline slides into. There will be the "button", shiny or a hole.
Re: 1969 B body rear assembly problems HELP [Re: mro] #2276006
03/25/17 02:55 PM
03/25/17 02:55 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Ill check - should there be a little plate on the tip of the axle?
Re: 1969 B body rear assembly problems HELP [Re: mro] #2276008
03/25/17 02:57 PM
03/25/17 02:57 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
How do I post a pic?
Re: 1969 B body rear assembly problems HELP [Re: mro] #2276016
03/25/17 03:10 PM
03/25/17 03:10 PM
nothing on the splined tip of the axle, it is cutoff square with a slight chamfering around the perimeter, just the shallow hole in the center for when they chucked it up in the lathe to machine the shaft.
Re: 1969 B body rear assembly problems HELP [Re: mro] #2276021
03/25/17 03:16 PM
03/25/17 03:16 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
What case is the center section, 742, 489? 489 would have a piece in there, open or sure grip, but a 742 has the button as mention that will come out.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 1969 B body rear assembly problems HELP [Re: mro] #2276220
03/25/17 11:04 PM
03/25/17 11:04 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Is there any chance the button fell off and is floating around ?
Re: 1969 B body rear assembly problems HELP [Re: Silver70] #2276227
03/25/17 11:17 PM
03/25/17 11:17 PM
cbusters Offline
cbusters  Offline
A clutch type center would fit in many different carrier housings. I have had a early clutch type in a 489 case, so that is not a guide. The OP needs to look or have sometime "in the know" look and figure out if there is something missing. We are assuming there is an adjuster on one axle. We are assuming there are still tapered bearings on the axles. We are assuming the installed axle is seated. Too many variables right now.
Re: 1969 B body rear assembly problems HELP [Re: cbusters] #2276507
03/26/17 02:34 PM
03/26/17 02:34 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
True but it's a good start to figure out the issue... It would be the first thing I would check.
Re: 1969 B body rear assembly problems HELP [Re: mro] #2277105
03/27/17 12:42 PM
03/27/17 12:42 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
May have found the problem - one axle is 1/4 shorter then the other - buttons are in place - the axles should be the same height right? They must have got mixed up in storage
Re: 1969 B body rear assembly problems HELP [Re: mro] #2277112
03/27/17 12:49 PM
03/27/17 12:49 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
scratch that - they are both 29 1/4
Re: 1969 B body rear assembly problems HELP [Re: mro] #2277114
03/27/17 12:51 PM
03/27/17 12:51 PM
I wouldn't think there is another app that has axles that close to B body dimentions. compare the bearing/adjuster plate, the items at the outer end of the axles, their spacing on the axle & see if you see any discrepency. are you using the thick or the thin white foam seals? If I can find my thin felpros' I will measure them compared to the thick eBay ones I (also) have.
Re: 1969 B body rear assembly problems HELP [Re: mro] #2277160
03/27/17 02:24 PM
03/27/17 02:24 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
489 case
Re: 1969 B body rear assembly problems HELP [Re: mro] #2277162
03/27/17 02:26 PM
03/27/17 02:26 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
I talked with the guy working on this and he said when he adjusts the right side it has no effect on the left
Re: 1969 B body rear assembly problems HELP [Re: mro] #2277163
03/27/17 02:27 PM
03/27/17 02:27 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
- axles 29 1/4, buttons in place, 489 case, any ideas ?
