Header building Never again!!
#2276138
03/25/17 07:40 PM
03/25/17 07:40 PM
Posts: 739 WA
JD Dart
WA
Just finished doing a set for a friend of mine way too many hours and frustration to do this any more let more talent people do this. His car was a hard one to fit the tubes into.
best so far 8.53 @ 158.59 MPH 60'1.240
Re: Header building Never again!!
[Re: JD Dart]
#2276142
03/25/17 07:52 PM
03/25/17 07:52 PM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
I built my own, I would do it again in a second. Loved it.
Brutal tight area and 2 1/8" primaries, I made spike collectors and equal length tubes, fit like a glove!
CrAzYMoPaRGuY
[Re: JD Dart]
#2276156
03/25/17 08:20 PM
03/25/17 08:20 PM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Nice welds though!
[Re: Mopar_Rich]
#2276157
03/25/17 08:35 PM
03/25/17 08:35 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I like doing them... sometimes its a bit more time to get them as close to equal length as possible
[Re: JD Dart]
#2276160
03/25/17 08:51 PM
03/25/17 08:51 PM
Posts: 7,480 Minnesota
Hemi_Joel
Minnesota
I know of dyno tests that indicate equal length is unimportant. I wouldn't spend my time trying to make them equal length. Make the bends as smooth as possible, that is more important.
JD, those headers you built are art!
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2276170
03/25/17 09:06 PM
03/25/17 09:06 PM
MR_P_BODY
JD, those headers you built are art! Equal length is like port timing.. I try to get it as close as I can.. I seen it on the dyno.. on my W-9 set is within .1 in length.. but what do I know
[Re: MR_P_BODY]
#2276177
03/25/17 09:24 PM
03/25/17 09:24 PM
Hemi_Joel
Minnesota
Equal length is like port timing.. I try to get it as close as I can.. I seen it on the dyno.. on my W-9 set is within .1 in length.. but what do I know More than me, you've been there, done that. My friend Jay Brown was meticulous about always building equal length. Then someone told him smooth bends are more important than equal length. He didn't really believe it. He has his own dyno, so he did back to back tests. He reports to me that equal length didn't make any more power. But you have your own experience, go with what you know.
[Re: Hemi_Joel]
#2276181
03/25/17 09:41 PM
03/25/17 09:41 PM
MR_P_BODY
Equal length is like port timing.. I try to get it as close as I can.. I seen it on the dyno.. on my W-9 set is within .1 in length.. but what do I know More than me, you've been there, done that. My friend Jay Brown was meticulous about always building equal length. Then someone told him smooth bends are more important than equal length. He didn't really believe it. He has his own dyno, so he did back to back tests. He reports to me that equal length didn't make any more power. But you have your own experience, go with what you know. Smooth bends are a standard.. you have to do them if you want any decent header.. but equal length is important also EDIT Also if you can you want large radius bends.. but number 1 thing is they have to fit in the car
[Re: JD Dart]
#2276207
03/25/17 10:37 PM
03/25/17 10:37 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Never again? That would be a shame. Looks like you did a nice job.
[Re: TRENDZ]
#2276214
03/25/17 10:49 PM
03/25/17 10:49 PM
Posts: 1,881 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
Never again? That would be a shame. Looks like you did a nice job. I agree,very nice,but I also understand the "never again" feeling on a project!
[Re: JD Dart]
#2276218
03/25/17 11:01 PM
03/25/17 11:01 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I still like my JD LT's...
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: cudaman1969]
#2276261
03/26/17 12:24 AM
03/26/17 12:24 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
If I were doing them for a living there's a plastic tubing kit where there's a ton of curves and straights that snap together and make each tube (all four at one time). They come in different size tubes and allow for any bend and really look like a header when all snaped together, infinitely adjustable. They start at $245 and go up, no more guessing and trial fitting. Isn't that the kit that you send in to have the pipes bent to there shape?
[Re: rowin4]
#2276269
03/26/17 12:37 AM
03/26/17 12:37 AM
Posts: 180 merrill, wisconsin
voigtspeed
merrill, wisconsin
Look's Good to me something to be proud of... If there is a next time it will go faster and pay better people who understand the process will pay.........
ACCELERATION SPECIALIST
[Re: rowin4]
#2276286
03/26/17 01:34 AM
03/26/17 01:34 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Yea and no. Stainless Header Co. has jointed pipe kit you can use for a model so they can make make a header to your design. I suspect if you had the ICE kit they'ld be fine with that too. But you can buy the ICE blocks for your own projects too. My impression is that they can be helpful but are not magic. It probably depends on the builder and the specific situation. Brian Slowe built me a set of headers last year and in this case he did not use them (even though he has them). Here's a post about them over in Speedtalk. http://speedtalk.com/forum/viewtopic.php?f=1&t=41836&p=565969#p565969BTW That's a great thread to read in general for anyone interested in headers, at least the first 5 plus pages anyway. Lots of points about building as well as design and theory all mixed in.
[Re: JD Dart]
#2276314
03/26/17 02:35 AM
03/26/17 02:35 AM
Posts: 8,844 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Hot rod did a test (is a you tube videos of it) where they did back to pulls on a set of headers. Then took a hammer and beat a dent into a tube ....made a pull...more dents...a lot of dents. And I think was like a 6 or 7 hp loss. And the headers looked like junk
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#2276319
03/26/17 03:02 AM
03/26/17 03:02 AM
MR_P_BODY
Hot rod did a test (is a you tube videos of it) where they did back to pulls on a set of headers. Then took a hammer and beat a dent into a tube ....made a pull...more dents...a lot of dents. And I think was like a 6 or 7 hp loss. And the headers looked like junk I watched that some time back.. I do have a couple of questions on it.. first.. if a bented up set of headers works just as well.. doesnt that give you the idea that the area of those were to large to start with.. second.. if that held true.. why arent all the pro stocks beating up there headers.. my opinion on that vid is they were too big to start with.. but a lot of people use to big
