How do you adapt an older Dana 60-2 to a '96 Ram 1500? #2275458
03/24/17 04:34 PM
03/24/17 04:34 PM
Graham, WA
P
Polarapete Offline OP
P
Graham, WA
I built a Dana 60-2 for my '87 D100 to replace the 8.25" that it came with. I sold the truck and the new owner did not want it. A club member has been having problems with the 9.25" in his 4x4 Ram. I would like to sell the Dana to him. It is fresh with a 4.10 gear on a PowerLock diff with 35 spline axles, new seals and fresh 12" Drum Brakes. I narrowed the axle to fit the '87 and I am sure it will mount in the Ram 1500 with just a few issues, the driveshaft will have to be shortened slightly, the brake lines will have to be made up and those are no big deal.
One thing seems to be an issue and that is the Ram has ABS brakes and the Dana does not have those pieces. I need to know what we have to do with that??
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: Polarapete] #2275479
03/24/17 05:46 PM
03/24/17 05:46 PM
dogdays Offline
dogdays  Offline
The letters S-O-L apply here. The ABS uses a speed sensor for the rear wheels that mounts in the differential and counts the teeth on a tone wheel mounted to the gear carrier. It's going to take a lot of work to duplicate that setup in an older Dana 60 case.
Getting a newer D60 with the required parts would mean discarding everything except the axle shafts, brakes and gearset. I guess you could swap center sections but that would be major. Use the D60 in a vehicle that doesn't have
ABS, or else mounts the speed sensors in the brake housing.
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: dogdays] #2275487
03/24/17 06:13 PM
03/24/17 06:13 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
Not sure how big a deal this is, but they went to 3" wide springs in '94 vs. the earlier 2.5" wide springs.
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: 3hundred] #2275531
03/24/17 07:18 PM
03/24/17 07:18 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
If you were close I would give you a 96 Dana 60 that was in my 2500 Ram. I lost a carrier bearing and just bolted in a Dana 70, not easy to find a 60 for a 96. shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: dogdays] #2275544
03/24/17 07:43 PM
03/24/17 07:43 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
Originally Posted By dogdays
The letters S-O-L apply here. The ABS uses a speed sensor for the rear wheels that mounts in the differential and counts the teeth on a tone wheel mounted to the gear carrier. It's going to take a lot of work to duplicate that setup in an older Dana 60 case....
Why couldn't you mount a tone ring on the pinion grease slinger with the right number of teeth? Pickup mounted to the snubber?
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: Polarapete] #2275705
03/25/17 12:42 AM
03/25/17 12:42 AM
All the Dana 60-2 I've seen had 2.5 inch diameter axle tubes, does yours?
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: Polarapete] #2275819
03/25/17 08:07 AM
03/25/17 08:07 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
If you want a ratio less than 3.54
What would it take to adapt a
Dana 61 to a 1995 Ram?
Is my fuzzy memory correct that you can get 3.07
only by going to a Dana 61 housing?
http://eastcoastgearsupply.com/ft-54-dana-60-61tech.html
Have the newest 9.25 diffs with the modification using lower friction ball bearings
from around year 2009 onward
Also done away with the frequent pinion bearing seal failures
That plagued Ram 1500s from 1994 to at least 2001?
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: Cab_Burge] #2275984
03/25/17 02:10 PM
03/25/17 02:10 PM
Graham, WA
P
P
Graham, WA
I measured it at 2.875"
2008 Honda Element
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: 6PakBee] #2275990
03/25/17 02:17 PM
03/25/17 02:17 PM
Graham, WA
P
P
Graham, WA
I think that is what his 9.25" has on the front side of the diff, but I have not been under it or opened the rear cover...I will ask him. I plan to build a few more Dana 60s because I have the case spreader, the setup bearings and a large pile of shims. And once you build one they seem to last forever regardless of how you beat on them.
2008 Honda Element
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: Polarapete] #2276551
03/26/17 03:40 PM
03/26/17 03:40 PM
dogdays Offline
dogdays  Offline
Tone ring on the pinion? Probably but getting the exact number of teeth would be nearly impossible. Shoot, anything is possible but is it worth it? Practicality comes into play here.
Better to sell the Dana and use the $ to get a rear end that won't require major rework to use.
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: dogdays] #2276580
03/26/17 04:18 PM
03/26/17 04:18 PM
North Dakota
North Dakota
I don't want to beat a dead horse here but I'd bet anyone that I could take the slinger, braze a ring on it, lay the tooth pattern out on the ring, and cut the teeth into the ring with a wafer wheel.
And it would work.
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500? [Re: 6PakBee] #2276708
03/26/17 07:57 PM
03/26/17 07:57 PM
Graham, WA
P
P
Graham, WA
And it would work.
I don't think your suggestion is unreasonable at all and I appreciate the idea....more food for thought.
2008 Honda Element
