How do you adapt an older Dana 60-2 to a '96 Ram 1500?
#2275458
03/24/17 04:34 PM
03/24/17 04:34 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I built a Dana 60-2 for my '87 D100 to replace the 8.25" that it came with. I sold the truck and the new owner did not want it. A club member has been having problems with the 9.25" in his 4x4 Ram. I would like to sell the Dana to him. It is fresh with a 4.10 gear on a PowerLock diff with 35 spline axles, new seals and fresh 12" Drum Brakes. I narrowed the axle to fit the '87 and I am sure it will mount in the Ram 1500 with just a few issues, the driveshaft will have to be shortened slightly, the brake lines will have to be made up and those are no big deal.
One thing seems to be an issue and that is the Ram has ABS brakes and the Dana does not have those pieces. I need to know what we have to do with that??
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: How do you adapt an older Dana 60-2 to a '96 Ram 1500?
[Re: Polarapete]
#2275479
03/24/17 05:46 PM
03/24/17 05:46 PM
dogdays
The letters S-O-L apply here. The ABS uses a speed sensor for the rear wheels that mounts in the differential and counts the teeth on a tone wheel mounted to the gear carrier. It's going to take a lot of work to duplicate that setup in an older Dana 60 case.
Getting a newer D60 with the required parts would mean discarding everything except the axle shafts, brakes and gearset. I guess you could swap center sections but that would be major. Use the D60 in a vehicle that doesn't have ABS, or else mounts the speed sensors in the brake housing.
[Re: dogdays]
#2275487
03/24/17 06:13 PM
03/24/17 06:13 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Not sure how big a deal this is, but they went to 3" wide springs in '94 vs. the earlier 2.5" wide springs.
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: dogdays]
#2275544
03/24/17 07:43 PM
03/24/17 07:43 PM
Posts: 10,702 North Dakota
6PakBee
North Dakota
The letters S-O-L apply here. The ABS uses a speed sensor for the rear wheels that mounts in the differential and counts the teeth on a tone wheel mounted to the gear carrier. It's going to take a lot of work to duplicate that setup in an older Dana 60 case.... Why couldn't you mount a tone ring on the pinion grease slinger with the right number of teeth? Pickup mounted to the snubber?
[Re: Polarapete]
#2275705
03/25/17 12:42 AM
03/25/17 12:42 AM
Posts: 43,123 Bend,OR USA
Cab_Burge
All the Dana 60-2 I've seen had 2.5 inch diameter axle tubes, does yours?
[Re: Polarapete]
#2275819
03/25/17 08:07 AM
03/25/17 08:07 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
If you want a ratio less than 3.54 What would it take to adapt a Dana 61 to a 1995 Ram? Is my fuzzy memory correct that you can get 3.07 only by going to a Dana 61 housing? http://eastcoastgearsupply.com/ft-54-dana-60-61tech.htmlHave the newest 9.25 diffs with the modification using lower friction ball bearings from around year 2009 onward Also done away with the frequent pinion bearing seal failures That plagued Ram 1500s from 1994 to at least 2001?
[Re: Cab_Burge]
#2275984
03/25/17 02:10 PM
03/25/17 02:10 PM
Polarapete
Graham, WA
All the Dana 60-2 I've seen had 2.5 inch diameter axle tubes, does yours? I measured it at 2.875"
[Re: 6PakBee]
#2275990
03/25/17 02:17 PM
03/25/17 02:17 PM
Polarapete
Graham, WA
The letters S-O-L apply here. The ABS uses a speed sensor for the rear wheels that mounts in the differential and counts the teeth on a tone wheel mounted to the gear carrier. It's going to take a lot of work to duplicate that setup in an older Dana 60 case.... Why couldn't you mount a tone ring on the pinion grease slinger with the right number of teeth? Pickup mounted to the snubber? I think that is what his 9.25" has on the front side of the diff, but I have not been under it or opened the rear cover...I will ask him. I plan to build a few more Dana 60s because I have the case spreader, the setup bearings and a large pile of shims. And once you build one they seem to last forever regardless of how you beat on them.
[Re: dogdays]
#2276580
03/26/17 04:18 PM
03/26/17 04:18 PM
6PakBee
North Dakota
Tone ring on the pinion? Probably but getting the exact number of teeth would be nearly impossible. I don't want to beat a dead horse here but I'd bet anyone that I could take the slinger, braze a ring on it, lay the tooth pattern out on the ring, and cut the teeth into the ring with a wafer wheel. And it would work.
[Re: 6PakBee]
#2276708
03/26/17 07:57 PM
03/26/17 07:57 PM
Polarapete
Graham, WA
Tone ring on the pinion? Probably but getting the exact number of teeth would be nearly impossible. I don't want to beat a dead horse here but I'd bet anyone that I could take the slinger, braze a ring on it, lay the tooth pattern out on the ring, and cut the teeth into the ring with a wafer wheel. And it would work. I don't think your suggestion is unreasonable at all and I appreciate the idea....more food for thought.
