Spark plug for 511 break in #2275788
03/25/17 03:12 AM
03/25/17 03:12 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
What plug would you guys recommend for 511 cam break in? Inexpensive would be fine i assume . i use an ice ignition and they recommend non resistor plug, but would that matter for break in purposes only? Thanks
Re: Spark plug for 511 break in [Re: mopar dave] #2275803
03/25/17 04:21 AM
03/25/17 04:21 AM
I don't remember the details of your motor, compression ratio or cylinder heads and what fuel your going to use help shruggy
Colder will foul sooner, hotter will burn hotter work
If it is a aluminum headed BB with 3/4 reach plugs with a 5/8 inch body I would probably look at Champion C9YC(maybe a RC9YC) or a Autolite #3933 twocents
Re: Spark plug for 511 break in [Re: Cab_Burge] #2275804
03/25/17 05:16 AM
03/25/17 05:16 AM
Mt Morris Michigan
Mt Morris Michigan
11.3:1 on the compression and victor max wedge for heads.
Re: Spark plug for 511 break in [Re: mopar dave] #2275842
03/25/17 10:01 AM
03/25/17 10:01 AM
crabman173
crabman173
again the answer for plug applications is the NGK tech line they answer first ring and if you know your CR they put you on the money first time--best in the business
Re: Spark plug for 511 break in [Re: ] #2275844
03/25/17 10:08 AM
03/25/17 10:08 AM
Mt Morris Michigan
Mt Morris Michigan
Cool, i will give them a call. Thanks
Re: Spark plug for 511 break in [Re: mopar dave] #2275933
03/25/17 12:51 PM
03/25/17 12:51 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I alway use used plugs, fire it up , check for leaks, warm it to temp, tune it in, shut it off and check the valve adjustment, replace the plugs with new. I have found by doing this it doesn't contaminate the plugs with the extra oil from the assembly. Just the way I do it, others may differ.
Re: Spark plug for 511 break in [Re: mopar dave] #2275938
03/25/17 12:55 PM
03/25/17 12:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
NGK #7
Re: Spark plug for 511 break in [Re: Thumperdart] #2275941
03/25/17 01:06 PM
03/25/17 01:06 PM
Mt Morris Michigan
Mt Morris Michigan
yeah didn't want to spend a lot on plugs that wont be in it long.
Dom, 7's for break in or at the track?
Re: Spark plug for 511 break in [Re: mopar dave] #2275997
03/25/17 02:33 PM
03/25/17 02:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
7's are what I run at 12.1.1 and even 8's w/a sharp tune........
Re: Spark plug for 511 break in [Re: mopar dave] #2276001
03/25/17 02:47 PM
03/25/17 02:47 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
For break in I use the colder NGK "BKR8E" Stock Number R5671A-8/4554
https://www.ngk.com/product.aspx?zpid=10044
The step hotter BKR7E stock number 5791 seems easier to find, and cheaper at summit racing.
https://www.summitracing.com/parts/ngk-5791
I forgot to mention these are the shorter "ISO" type plugs that have the shorter distance from seat to plug wire tip (50.5mm) vs the Longer JIS (53.0mm) length. The shorter length helps #2 plug wire to inner fender clearance on the 440.
The starting letters "BC" would be the JIS length.
Re: Spark plug for 511 break in [Re: mopar dave] #2276078
03/25/17 05:26 PM
03/25/17 05:26 PM
AndyF Offline
AndyF  Offline
I use NGK 6987 in my 470 engine with similar compression ratio. The 6987 has an extra long projected nose and an extra wide gap. It is also a fairly inexpensive plug. It is a factory plug for some of the newer cars. I've been running this plug for a few years now in different engines. I haven't had any problems yet with it but you probably need a decent ignition system to fire the big gap.
Re: Spark plug for 511 break in [Re: AndyF] #2276194
03/25/17 10:08 PM
03/25/17 10:08 PM
Mt Morris Michigan
Mt Morris Michigan
I just thru away a couple used sets of 7's that I didn't think I would need. ok, thanks guys ill check these out. just need something inexpensive for now.
