Re: Spark plug for 511 break in
[Re: mopar dave]
#2275842
03/25/17 10:01 AM
03/25/17 10:01 AM
crabman173
crabman173
again the answer for plug applications is the NGK tech line they answer first ring and if you know your CR they put you on the money first time--best in the business
[Re: mopar dave]
#2275933
03/25/17 12:51 PM
03/25/17 12:51 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
I alway use used plugs, fire it up , check for leaks, warm it to temp, tune it in, shut it off and check the valve adjustment, replace the plugs with new. I have found by doing this it doesn't contaminate the plugs with the extra oil from the assembly. Just the way I do it, others may differ.
[Re: mopar dave]
#2275938
03/25/17 12:55 PM
03/25/17 12:55 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
11.3:1 on the compression and victor max wedge for heads. NGK #7
[Re: mopar dave]
#2275997
03/25/17 02:33 PM
03/25/17 02:33 PM
Thumperdart
State of confusion
7's are what I run at 12.1.1 and even 8's w/a sharp tune........
[Re: mopar dave]
#2276001
03/25/17 02:47 PM
03/25/17 02:47 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
For break in I use the colder NGK "BKR8E" Stock Number R5671A-8/4554 https://www.ngk.com/product.aspx?zpid=10044The step hotter BKR7E stock number 5791 seems easier to find, and cheaper at summit racing. https://www.summitracing.com/parts/ngk-5791I forgot to mention these are the shorter "ISO" type plugs that have the shorter distance from seat to plug wire tip (50.5mm) vs the Longer JIS (53.0mm) length. The shorter length helps #2 plug wire to inner fender clearance on the 440. The starting letters "BC" would be the JIS length.
