Trend Tool Steel Lifters #2272232
03/19/17 11:18 AM
03/19/17 11:18 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Has anybody tried these and what did they recommend for a cast cam core?- as they have a lot of options. And can they be used repeatedly?
Re: Trend Tool Steel Lifters [Re: Hot 340] #2272344
03/19/17 02:10 PM
03/19/17 02:10 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
I can't answer your question,but the Barton
tool steel lifters are on sale now.
Mike
Re: Trend Tool Steel Lifters [Re: Hot 340] #2272348
03/19/17 02:19 PM
03/19/17 02:19 PM
Locomotion Offline
Locomotion  Offline
Here is a long discussion about lifter and cam material and coatings. Might answer a few questions.
Classracer.com lifter discussion
Re: Trend Tool Steel Lifters [Re: Hot 340] #2272662
03/19/17 11:45 PM
03/19/17 11:45 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I checked out their website and admit it left me a bit confused. They have a number of options with a pretty wide price range, and it wasn't clear what some of the differences even were. It did say they're reusable, but also mentioned they can be returned to have the faces re-profiled... but I don't know if that means you're supposed to have them refaced before being reused
Like I said, kind of confusing.
Re: Trend Tool Steel Lifters [Re: Hot 340] #2272737
03/20/17 02:18 AM
03/20/17 02:18 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have them in my 512 ci street strip car, they said to use cast core, & non coated lifters, 2500 street miles & so far so good.
Re: Trend Tool Steel Lifters [Re: Hot 340] #2272741
03/20/17 02:26 AM
03/20/17 02:26 AM
missouri,usa
cryplydog Offline
cryplydog  Offline
missouri,usa
I have a set in my 505-B. I think they weighed about 78-g verses 112 or so and they have a oil hole in the face. I've ran mine a couple years and love them as well as the trend pushrods. If ever needed they will regrind the faces but I don't see that happening. running iron lifters and a iron cam is asking for trouble in my opinion regardless of the reasons. I wiped a new cam/lifters and it ruined my engine 5 years ago and it shouldn't have happened. I use a comp solid lift cam as well as Hughs rockers and I don't over spring my engines. running dissimilar materials along with pressured oil I believe is the answer and I didn't think the cost was bad and great people to deal with. Oh yeah,prime and use top grade oil. Whats a set of top grade iron lifters w/oil hole cost?
Re: Trend Tool Steel Lifters [Re: Hot 340] #2272871
03/20/17 11:32 AM
03/20/17 11:32 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
I have Barton's lifters in my engine. Does anyone know who makes them?
Master, again and still
Re: Trend Tool Steel Lifters [Re: DaveRS23] #2272904
03/20/17 12:17 PM
03/20/17 12:17 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I put the EDM solid lifters in my 600 plus lift cam in my 422 small block. They seem to be working but the next time this engine comes apart I'm upgrading to a bigger roller cam. ( R3 block grinding necessary )
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trend Tool Steel Lifters [Re: DaveRS23] #2272933
03/20/17 12:59 PM
03/20/17 12:59 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Trend
2011 Drag Pak Challenger
Re: Trend Tool Steel Lifters [Re: rickseeman] #2273243
03/20/17 08:50 PM
03/20/17 08:50 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Being as hard as they are, they should swap over from cam to cam. Like anything though, they will wear out eventually. I see what you mean Brad, the options aren't the clearest, if I was ordering them I'd be contacting Trend direct and telling them what I want. The DLC coating seems to almost double the cost.
Alan Jones
Re: Trend Tool Steel Lifters [Re: LA360] #2273260
03/20/17 09:22 PM
03/20/17 09:22 PM
dogdays Offline
dogdays  Offline
DLC = diamond-like coating
Nascar has been using it on wristpins for years. It isn't cheap, the pins are very expensive. As I understand it it's like growing a diamond crystal on the outside of the part.
One brand name for DLC is Casidiam.
R.
Re: Trend Tool Steel Lifters [Re: dogdays] #2273274
03/20/17 09:40 PM
03/20/17 09:40 PM
LA360 Offline
LA360  Offline
It's very slippery as well once oil comes in contact with it. I was astounded at just how slippery
Alan Jones
Re: Trend Tool Steel Lifters [Re: Hot 340] #2273284
03/20/17 09:50 PM
03/20/17 09:50 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
DLC is also used on dirt bike forks- only on the factory level suspensions though. No bike has come with it stock if I remember correctly.
Re: Trend Tool Steel Lifters [Re: rickseeman] #2273290
03/20/17 09:55 PM
03/20/17 09:55 PM
Benton, IL.
Special needs idiot
Special needs idiot
Benton, IL.
Trend
Thank you!
Re: Trend Tool Steel Lifters [Re: Hot 340] #2273310
03/20/17 10:21 PM
03/20/17 10:21 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Had a set in my 605 Hemi last year.....Just go roller and be done with it.
I don;t care what oil, break in, etc, etc you do, its gonna fail.....
Re: Trend Tool Steel Lifters [Re: Dragula] #2273535
03/21/17 10:07 AM
03/21/17 10:07 AM
PA
Harry's Taxi 2 Offline
PA
What happened to yours?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Trend Tool Steel Lifters [Re: Hot 340] #2274425
03/22/17 08:04 PM
03/22/17 08:04 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Been running MRL performance lifters in my 410cui small block with plenty of street driving since 2013 with zero issues.
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Trend Tool Steel Lifters [Re: slammedR/T] #2274861
03/23/17 04:10 PM
03/23/17 04:10 PM
BradH Offline
BradH  Offline
Roller or flat-tappet? I know MRL sells B.A.M. roller lifters, but didn't think he had anything special in an SFT.
