1970 440 HP Convertor Weights #2274468
03/22/17 09:28 PM
03/22/17 09:28 PM
North Dakota
6PakBee Online content OP
6PakBee  Online Content OP
North Dakota
After nearly three hours of searching I cannot find anything definitive about the torque converter weights for a 1970 440 HP. I can find tons of information on cast crank weights but not the forged crank heavy rod 440's. Does the converter for a 440 HP have weights? If so how much weight? Is there a weight kit for this (can't find an application in Mopar Performance). Does it straddle the drain plug like the typical converter weight?
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274531
03/22/17 11:02 PM
03/22/17 11:02 PM
Sudbury, ontario canada
750-h2 Offline
750-h2  Offline
First thing to do is make sure your engine is externally balanced by checking if it has the balance weight on the front of the harmonic balancer. If it does according to the Mopar Performance catalogue you will need to buy a neutral balance torque converter and then buy weight kit part # P4120241. This kit is for externally balanced cast cranks as well as the externally balanced 1970 & 1971 440 six pack engines and all other 440's with heavy rods[all have forged cranks]. Kit comes with a template and instructions.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274543
03/22/17 11:24 PM
03/22/17 11:24 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Yes they have wights and they are located on either side of the drain
Re: 1970 440 HP Convertor Weights [Re: 750-h2] #2274602
03/23/17 12:56 AM
03/23/17 12:56 AM
North Dakota
North Dakota
Originally Posted By 750-h2
.....buy weight kit part # P4120241. This kit is for externally balanced cast cranks as well as the externally balanced 1970 & 1971 440 six pack engines and all other 440's with heavy rods[all have forged cranks]. Kit comes with a template and instructions.
I saw that kit during my search and every time it popped up the application was listed as:
Torque Converter Balance Weight & Positioning Template Kit
Fits Most 1971-'79 383/440 (with cast crank)
Fits 1971-'92 360
Fits 1971-'76 340 (with cast crank)
There is no mention of the '70 heavy rod steel crank 440. Do you have a copy of the instructions or some other documentation that indicates this kit has this coverage? Appreciate the help.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274639
03/23/17 03:32 AM
03/23/17 03:32 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I had a '70 440 HP (I think that is the "F" code?) in the '69 convertible when I bought it, but it was a 4-speed. I don't recall any balance stuff on the flywheel? I think the flywheel and clutch assembly is still in a box around here. I sold the engine/trans to a guy doing a superbird clone.
The 505" stroked 440 in my car is the '69 "E" code engine.
Re: 1970 440 HP Convertor Weights [Re: 451Mopar] #2274646
03/23/17 05:31 AM
03/23/17 05:31 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The flywheel in 70 has no weights added. It has material that is removed to achieve the balance.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274660
03/23/17 09:29 AM
03/23/17 09:29 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
You can buy a flex plate with the proper weights on it to balance the motor and then use a neutral balance converter.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274693
03/23/17 10:51 AM
03/23/17 10:51 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
The B&M plate has a notch cut to compensate for the imbalance the heavy rods create. It can only be assembled one way.
Then you are not tied to converter welding.
This is what we used on our 70.
Joe
Re: 1970 440 HP Convertor Weights [Re: fastmark] #2274694
03/23/17 10:52 AM
03/23/17 10:52 AM
North Dakota
North Dakota
That sounded like a real plan until I checked. Anyone I could find did not have an application for a forged crank externally balanced engine. Cast crank yes, forged no. Maybe I'll just have to start calling.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274704
03/23/17 11:20 AM
03/23/17 11:20 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
That is strange because our B&M flexplate with the notch doesn't look
like the ones they're showing, ours has a much smaller notch.
We bought ours maybe 10 years ago.
Maybe it has been discontinued, I'm going to see if I can contact B&M for an answer.
Joe
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274709
03/23/17 11:30 AM
03/23/17 11:30 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Talked to a rep at B&M this AM and he was at a loss as to the difference in
flex plate appearance from mine to what it shows now.
But ours is a forged steel crank and all is well as far as we can tell.
Sorry I couldn't help, Joe
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274710
03/23/17 11:35 AM
03/23/17 11:35 AM
Mass
charge70 Offline
charge70  Offline
Mass
Bee,I have the drive train out of my 70 R/T at home.It's a 440 u-code car that still has the original motor and trans. I can take a pic of the face of the converter if you want me to.Let me know. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274715
03/23/17 11:50 AM
03/23/17 11:50 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I thought the torque converters on forged crank 440's were all neutral balance, 6pack rods or not? I think the external balancing on 6 pack rod engines was done on the harmonic balancer
Re: 1970 440 HP Convertor Weights [Re: charge70] #2274725
03/23/17 12:10 PM
03/23/17 12:10 PM
North Dakota
North Dakota
John, that would be great. I've sent you a PM.
Re: 1970 440 HP Convertor Weights [Re: jlatessa] #2274732
03/23/17 12:20 PM
03/23/17 12:20 PM
North Dakota
North Dakota
Joe, thanks for going the extra step and calling B&M. thumbs I was planning on doing that this morning but you doing it was much better. You could start the conversation with "I bought this flexplate from you..." If I had been asked any details I'd been dead in the water.
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274855
03/23/17 04:03 PM
03/23/17 04:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The B&M number is 10238
https://www.summitracing.com/parts/bmm-10238
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274858
03/23/17 04:06 PM
03/23/17 04:06 PM
750-h2 Offline
750-h2  Offline
Fits 1971-'92 360
6PakBee here is a link to the Mopar performance catalogue. Go to the auto trans section and look at the torque converter application chart page 91. There they tell you to use the weight kit P4120241 with the 440 six pack with heavy rods.
http://www.mopar.ca/assets/pdf/restoration/CATALOGUEDERESTAURATION2007.pdf
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274860
03/23/17 04:09 PM
03/23/17 04:09 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Aha, good find John, that's what ours looks like.
Now why the B&M guy didn't know about it????
You're all set now 6PakBee...
Joe
EDIT, the ad from Summit says "Not available" What the He__!
Re: 1970 440 HP Convertor Weights [Re: 6PakBee] #2274868
03/23/17 04:21 PM
03/23/17 04:21 PM
an8sec70cuda Offline
B&M 10238 is the correct flexplate for the forged crank, heavy (6 pack) rod 440 that is externally balanced.
It looks like they don't make it anymore? I've checked every website and no one has it (jegs, summit, mancini, etc.)...B&M's own website no longer shows it.
I may still have one out in the shop. The motor I ran it with ('71 HP 440) is now in a 4 speed car...when I freshened up the motor I had it internally balanced so I wouldn't have to deal w/ that ext. crap anymore.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 1970 440 HP Convertor Weights [Re: 750-h2] #2274878
03/23/17 04:37 PM
03/23/17 04:37 PM
North Dakota
North Dakota
[/b]http://www.mopar.ca/assets/pdf/restoration/CATALOGUEDERESTAURATION2007.pdf
Thanks for the link! It's somewhat disturbing that one has to go to a 10 year old catalog but I guess that is progress! Thanks again.
