ceramic coated headers #2274241
03/22/17 02:35 PM
03/22/17 02:35 PM
California
mickm Offline OP
mickm  Offline OP
California
have some oil that has dripped on the headers.
how do I clean these up? triple 000 steel wool takes it off quickly enough, but does dull the finish.
Re: ceramic coated headers [Re: mickm] #2274266
03/22/17 03:26 PM
03/22/17 03:26 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
I use aluminum wheel polish on my tti's, with typical blue shop towels and a lot of elbow grease. Don't know if a plastic dish washing pad would help or not, I might try that myself in an out of plan sight place sometime.
Re: ceramic coated headers [Re: mickm] #2274765
03/23/17 01:14 PM
03/23/17 01:14 PM
central il.
second 70 Offline
second 70  Offline
central il.
I use a wet SOS pad. Takes it off easily and polishes at the same time.
Re: ceramic coated headers [Re: mickm] #2274780
03/23/17 01:34 PM
03/23/17 01:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Carb cleaner (not brake clean) and aluminum wheel polish.
Doug
Re: ceramic coated headers [Re: mickm] #2275064
03/23/17 11:05 PM
03/23/17 11:05 PM
tucson az
frank Offline
frank  Offline
tucson az
I use a product called "Quick Glo". Saw it on I think Jay Lennos garage and it did amazing things. Decided to give it a try for some old Harley rims I had. It worked so when I had a oil leak on my TTI's I gave it a try and worked perfect again. Non abrasive, and you use a soft cloth. Made by a local guy in Louisiana I think in his basement. Good Stuff and not expensive
Re: ceramic coated headers [Re: frank] #2275383
03/24/17 02:03 PM
03/24/17 02:03 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Fast Orange hand cleaner. Smells nice, you probably already have some, and works well. TTI actually suggests it in their information as well. Think about it, it is just like polishing compound.
Todd
Re: ceramic coated headers [Re: sasquatch] #2277202
03/27/17 03:35 PM
03/27/17 03:35 PM
California
mickm Offline OP
mickm  Offline OP
California
Todd
hmmm.... good idea. never thought of that.
I found some chrome polish I had around, and that did the trick. will remember this for next time though...
