Best 408 stroker kits #2274020
03/22/17 12:06 AM
03/22/17 12:06 AM
Chicago Illinois
smallblock666 Offline OP
Chicago Illinois
Need to call on my fellow mopar people for a question. I'm in the process of building a 78 360 block ( will be stroked) with xe284h cam 360 2.02 j heads with major port work and will be going in a first gen Dakota big stall big gear. Question is this is my first stroker I'm putting together, willing to spend around 1,300-1,800 for the kit and would like to run 93 octane any suggestions on where to purchase or which kit I should go with. I'm terrible with determining pistons for compression ratios, really could use some help thanks guys and gals
Re: Best 408 stroker kits [Re: smallblock666] #2274059
03/22/17 01:10 AM
03/22/17 01:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What do you mean by big gear and big stall and what comp..
what will be your max rpm and is this 1/4 or 1/8 mile
wave
Re: Best 408 stroker kits [Re: smallblock666] #2274071
03/22/17 01:45 AM
03/22/17 01:45 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have a complete 408 magnum motor for sale. R/T heads and cam
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Best 408 stroker kits [Re: smallblock666] #2274074
03/22/17 02:08 AM
03/22/17 02:08 AM
P
Porter67 Offline
Porter67  Offline
P
Its hard to beat ones like Clegg or Shannon, both sell scat kits on ebay for a cast or forged balanced kit, you know your J heads are 68-72cc depending if they have ever been milled or have aftermarket valves. So compression ratio is simple to determine.
Re: Best 408 stroker kits [Re: smallblock666] #2274126
03/22/17 09:51 AM
03/22/17 09:51 AM
Chicago Illinois
Chicago Illinois
10 inch 3,800 stall. 4.10 gears. 1/4 mile. J heads have been milled slightly. 6,000 max rpm most likely
Re: Best 408 stroker kits [Re: smallblock666] #2274168
03/22/17 12:00 PM
03/22/17 12:00 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I bought most of the parts for last build from CnCMotorsports. I was going to go with a scat kit, but after I researched what bearings and pistons they came with and the route I wanted to go, I ended up buying each part that I wanted and asked CnCMotorsports to verify I had the right parts to make a "kit". It ended up being about the same price as a complete kit, but I ended up with the parts/brands that I wanted for MY build.
Re: Best 408 stroker kits [Re: smallblock666] #2274333
03/22/17 04:54 PM
03/22/17 04:54 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
The one problem I keep finding with the kits is compression ratios, either you get a flat top or a really big dish (typically 20CC). I usually end up piecing them together with the parts I want, the kits don't really save you much anyhow unless you go with a 4.125 or 4.250 then BPE can save you money.
Re: Best 408 stroker kits [Re: smallblock666] #2274571
03/23/17 12:15 AM
03/23/17 12:15 AM
Ohio
moparjoe360.4 Offline
Ohio
I'm no expert, and I don't have mine assembled yet but I just bought the Scat 98112bi from Summit. My combo sounds very similar to yours, with my ported 974 iron heads I have it figured at at or just under 11-1 comp .with a .040 head gasket. The kit was just under $1500 and every thing looked very nice. shruggy
