Where to buy radio suppressor/condensor? #2266167
03/09/17 01:33 PM
03/09/17 01:33 PM
usa
W
whomper1 Offline OP
whomper1  Offline OP
W
usa
I dont want a $40 one i found,
so i was hoping there is a cheaper alternative
it doesnt need to have dates or markings
i just want to have it in place on my car
any ideas on where to get?
or a part number that maybe an auto parts store could order one for me?
thanks
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2266224
03/09/17 03:18 PM
03/09/17 03:18 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
68 Charger R/T 440 auto
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2266226
03/09/17 03:23 PM
03/09/17 03:23 PM
usa
W
whomper1 Offline OP
whomper1  Offline OP
W
usa
yes the one that bolts to the coil bracket,
the one in your link is inside of the distributor for the points
i need one that looks like the one pictured
thanks
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2266321
03/09/17 06:08 PM
03/09/17 06:08 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I had no luck finding a cheap one.
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2266505
03/09/17 11:51 PM
03/09/17 11:51 PM
BlueRacer69 Offline
BlueRacer69  Offline
There are a couple of sellers on E-bay that have that exact one. Not very cheap, around $30 bucks I think. They do come in a number of different styles. Do a search on E-bay for: Radio Suppressor.
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2267053
03/10/17 09:46 PM
03/10/17 09:46 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Check out Summit.. $6.97..
https://www.summitracing.com/parts/smp-r...CFQx_fgoduMgGEg
Trim off tab to a narrow, short contact, solder a short wire lead with terminal and use heat shrink tubing over the solder joint.. May look a little different but works fine..
Just my $0.02... wink
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2267162
03/11/17 01:20 AM
03/11/17 01:20 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
thanks
Are you having radio/audio interference or ignition issues or just wanting to look somewhat original?
Re: Where to buy radio suppressor/condensor? [Re: A12] #2267168
03/11/17 01:24 AM
03/11/17 01:24 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Will one of these work: condenser Only $10 + $4.00 shipping
MikeR
Re: Where to buy radio suppressor/condensor? [Re: A12] #2267180
03/11/17 01:45 AM
03/11/17 01:45 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
If your issue is radio interference (RF) then you can try what was suggest to A12 owners back in the day when the fiberglass hoods didn't offer sufficient RF shielding.......this is no lie, this was released I think by Chrysler Canada back in the day. My '69 A12's antenna and a few other A12's antennas were moved to the rear quarter panel/fender and Dutchman panel back in the day for the RF issue and complaints. That's the reason the fiberglass hood T/A and AAR antennas were placed back there the next model year. They could have just skipped the expense and lined the under side of the hood with aluminum ("tin") foil and been done with it laugh2 laugh2
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2268881
03/13/17 09:22 PM
03/13/17 09:22 PM
Alabama
BigMoneyLewis Offline
Alabama
I only have one laying around , but it's in the box with my NOS Dart radio ,
so I can't sell it separate since it is part of the installation kit.
Greg
gregward@mchsi.com phone 256-852-0955
Re: Where to buy radio suppressor/condensor? [Re: BigMoneyLewis] #2269090
03/14/17 01:17 AM
03/14/17 01:17 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Greg, are the ones I linked above worth looking into?
Mike
Re: Where to buy radio suppressor/condensor? [Re: A12] #2269186
03/14/17 09:18 AM
03/14/17 09:18 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
MikeR
Mike, those are the condenser, mounts inside the ignition distributor.
The Noise suppressor mounts next to the ignition coil . 2 very different parts / functions
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2273781
03/21/17 05:15 PM
03/21/17 05:15 PM
usa
W
whomper1 Offline OP
whomper1  Offline OP
W
usa
thanks all for your input
me and some other local mopar guys were looking to buy, between the group of us we need like 10 and was hoping to find a cheap aftermarket lookalike, heck, it could even be empty and not functional, something we could get a bunch of for under $20 each
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2273786
03/21/17 05:28 PM
03/21/17 05:28 PM
Nanuet, NY
johntpr Offline
johntpr  Offline
Nanuet, NY
69 Daytona 4 speed
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2273796
03/21/17 05:43 PM
03/21/17 05:43 PM
usa
W
whomper1 Offline OP
whomper1  Offline OP
W
usa
$49 at that link, no help, but thanks
he is also difficult to order from
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2273917
03/21/17 09:14 PM
03/21/17 09:14 PM
WA
tman Offline
tman  Offline
WA
Standard motor products make several versions. Closest I found is this, if you don't care about appearances or there is one where you change the coil side terminal, but its even expensive. Ebay has some for $30+
http://www.rockauto.com/en/parts/standard+motor+products,RC23,radio+capacitor,21698
http://www.rockauto.com/en/parts/standard+motor+products,RC26,radio+capacitor,21698
http://www.rockauto.com/en/parts/standard+motor+products,RC15,radio+capacitor,21698
http://www.rockauto.com/en/parts/standard+motor+products,JC59,radio+capacitor,21698
http://www.rockauto.com/en/parts/standard+motor+products,RC28,radio+capacitor,21698
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2273975
03/21/17 11:02 PM
03/21/17 11:02 PM
Slidell, LA
Ronnman Offline
Ronnman  Offline
Slidell, LA
Whomper1 private message sent.
Ron
Re: Where to buy radio suppressor/condensor? [Re: whomper1] #2274143
03/22/17 10:55 AM
03/22/17 10:55 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
I have this nos one from a radio kit I had. $25 shipped
