Help identifying stage VI head #2272661
03/19/17 11:43 PM
03/19/17 11:43 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I need some information on a set of older Stage VI heads. I am told they have a casting number on them of; 4532885
Any help of information will be appreciated.
Thank you!
Re: Help identifying stage VI head [Re: GLR] #2272709
03/20/17 12:57 AM
03/20/17 12:57 AM
From what I understand using them on a B requires an RB intake so you might measure the port/intake mounting bolt heights (compare to a nearby "regular" head).
Re: Help identifying stage VI head [Re: GLR] #2272728
03/20/17 01:49 AM
03/20/17 01:49 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Well, I don't have the heads in my possession at this time. I know about having to use an RB intake with the heads when they are on a "B" engine.
I don't know if they are standard port or Max wedge port?
Re: Help identifying stage VI head [Re: GLR] #2272760
03/20/17 02:52 AM
03/20/17 02:52 AM
My 2001 MP catalogue shows 2 bare stage VI heads: 2.14/1.81. one with "small closed chamber" & "relocated spark plug" and the other with "std stage VI chamber" & "std plug location" BOTH with max wedge port window & both require offset rockers.
Re: Help identifying stage VI head [Re: GLR] #2272855
03/20/17 10:59 AM
03/20/17 10:59 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
So these heads should be the good one's to get? These are not the early one's that had the casting issues...correct?
Re: Help identifying stage VI head [Re: GLR] #2272917
03/20/17 12:42 PM
03/20/17 12:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How are you reading that from what Robert posted???
Is the number on the head cast in or stamped?
Re: Help identifying stage VI head [Re: GLR] #2272920
03/20/17 12:44 PM
03/20/17 12:44 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The "casting" number won't really tell you anything.
You need the part number from the box, or just "know" what you are looking at.
The only what I would call "good" stage 6's were the Chapmans.
All the others are a crap shoot for qc issues.
The best of the non-Chapman heads were the last ones made, which were cast by the Zeus foundry. They have the word "Zeus" cast into the top of the head.
There have been tons of threads for stage 6 heads through the years...... Just do a search.
Unless they have already been professionally prepared, and are a super bargain...... There will be more cost effective options out there.
Heres a good place to start:
http://www.moparts.org/Tech/Archive/bb/33.html
Re: Help identifying stage VI head [Re: GLR] #2272969
03/20/17 01:49 PM
03/20/17 01:49 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Stay away from early Stage 6. There are WAY better heads out there. Late model Chapman CNC are nice though.
Doug
Re: Help identifying stage VI head [Re: GLR] #2273043
03/20/17 03:19 PM
03/20/17 03:19 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thanks Dwayne, I guess I will have to look at the heads myself and see what they are and go from there. All I was given was the number on the head itself and that they are new.
Re: Help identifying stage VI head [Re: GLR] #2273105
03/20/17 04:57 PM
03/20/17 04:57 PM
So. Burlington, Vt.
So. Burlington, Vt.
Here's a good read of someone starting with the "raw" castings, and going through all the steps to end up with a finished pair of heads:
http://www.cuda-challenger.com/cc/index.php?topic=63063
