Re: Remote oil filter help
[Re: earthmover]
#2272574
03/19/17 09:44 PM
03/19/17 09:44 PM
Posts: 2,449 nc
earthmover
nc
[Re: earthmover]
#2272578
03/19/17 09:50 PM
03/19/17 09:50 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Wix r51515 has three times the flow of a regular filter. The media is more course than a stock filter so it can filter most all the oil all the time. To me that is a good thing.less chance of something big gatting into the rotating assembly.
[Re: earthmover]
#2272611
03/19/17 10:32 PM
03/19/17 10:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use a remote adapter to mount the filter..the filter just screws onto the remote.. I use AN 10 line on my set up
[Re: earthmover]
#2272752
03/20/17 02:43 AM
03/20/17 02:43 AM
Posts: 43,211 Bend,OR USA
Cab_Burge
[Re: earthmover]
#2272902
03/20/17 12:17 PM
03/20/17 12:17 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I like the Jomar no-bypass filters. It worked as designed when I had some metal bits come off the valve train, and saved the bottom end etc. They are hard to cut open though, as the can is thick. http://jomarperformance.com/pro-filter.php
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: earthmover]
#2272937
03/20/17 01:08 PM
03/20/17 01:08 PM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
I have the same thing as Cab. Wix Racing 51222R on a Peterson Fluid Systems remote with -10 lines. I actually have a K&N on there now but I have a whole case of the Wix filters. The remote has a nice 1/8" npt outlet for the Racepak.
