Re: Trend Tool Steel Lifters
[Re: Hot 340]
#2272662
03/19/17 11:45 PM
03/19/17 11:45 PM
BradH
I checked out their website and admit it left me a bit confused. They have a number of options with a pretty wide price range, and it wasn't clear what some of the differences even were. It did say they're reusable, but also mentioned they can be returned to have the faces re-profiled... but I don't know if that means you're supposed to have them refaced before being reused
Like I said, kind of confusing.
[Re: Hot 340]
#2272737
03/20/17 02:18 AM
03/20/17 02:18 AM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
I have them in my 512 ci street strip car, they said to use cast core, & non coated lifters, 2500 street miles & so far so good.
[Re: Hot 340]
#2272871
03/20/17 11:32 AM
03/20/17 11:32 AM
Posts: 12,226 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have Barton's lifters in my engine. Does anyone know who makes them?
Master, again and still
[Re: DaveRS23]
#2272904
03/20/17 12:17 PM
03/20/17 12:17 PM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I put the EDM solid lifters in my 600 plus lift cam in my 422 small block. They seem to be working but the next time this engine comes apart I'm upgrading to a bigger roller cam. ( R3 block grinding necessary )
[Re: rickseeman]
#2273243
03/20/17 08:50 PM
03/20/17 08:50 PM
Posts: 6,148 Melbourne , Australia
LA360
Being as hard as they are, they should swap over from cam to cam. Like anything though, they will wear out eventually. I see what you mean Brad, the options aren't the clearest, if I was ordering them I'd be contacting Trend direct and telling them what I want. The DLC coating seems to almost double the cost.
Alan Jones
[Re: Hot 340]
#2273284
03/20/17 09:50 PM
03/20/17 09:50 PM
Posts: 8,174 Plymouth, MI
Blusmbl
Plymouth, MI
DLC is also used on dirt bike forks- only on the factory level suspensions though. No bike has come with it stock if I remember correctly.
[Re: rickseeman]
#2273290
03/20/17 09:55 PM
03/20/17 09:55 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have Barton's lifters in my engine. Does anyone know who makes them? Trend Thank you!
[Re: Hot 340]
#2273310
03/20/17 10:21 PM
03/20/17 10:21 PM
Posts: 12,408 Taxes & Virus's R-US, NY
Dragula
Has anybody tried these and what did they recommend for a cast cam core?- as they have a lot of options. And can they be used repeatedly? Had a set in my 605 Hemi last year.....Just go roller and be done with it. I don;t care what oil, break in, etc, etc you do, its gonna fail.....
[Re: Dragula]
#2273535
03/21/17 10:07 AM
03/21/17 10:07 AM
Posts: 289 PA
Harry's Taxi 2
PA
Has anybody tried these and what did they recommend for a cast cam core?- as they have a lot of options. And can they be used repeatedly? Had a set in my 605 Hemi last year.....Just go roller and be done with it. I don;t care what oil, break in, etc, etc you do, its gonna fail..... What happened to yours?
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: Hot 340]
#2274425
03/22/17 08:04 PM
03/22/17 08:04 PM
Posts: 733 jacksonville,FLORIDA
slammedR/T
Been running MRL performance lifters in my 410cui small block with plenty of street driving since 2013 with zero issues.
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: slammedR/T]
#2274861
03/23/17 04:10 PM
03/23/17 04:10 PM
BradH
Been running MRL performance lifters in my 410cui small block with plenty of street driving since 2013 with zero issues. Roller or flat-tappet? I know MRL sells B.A.M. roller lifters, but didn't think he had anything special in an SFT.
