where to buy correct heater blower motor #2271344
03/17/17 07:52 PM
03/17/17 07:52 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
69 b body no air blower motor. thanks
Re: where to buy correct heater blower motor [Re: moparpro] #2271377
03/17/17 09:03 PM
03/17/17 09:03 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
rockauto
FOUR SEASONS 35502
Re: where to buy correct heater blower motor [Re: markz528] #2271470
03/17/17 11:47 PM
03/17/17 11:47 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
thank you very much.
Re: where to buy correct heater blower motor [Re: moparpro] #2277276
03/27/17 06:00 PM
03/27/17 06:00 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
i tried rock auto blower motor by four seasons and it does not line up with the exhaust tube from motor to heater box it is way off i can not connect exhaust pipe to motor not lined correctly.
Re: where to buy correct heater blower motor [Re: moparpro] #2277369
03/27/17 09:41 PM
03/27/17 09:41 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I went through this 10 years ago... Never could find the correct one that plugs into the tube..
On the flip side the aftermarket one works fine...
Re: where to buy correct heater blower motor [Re: moparpro] #2277426
03/27/17 11:17 PM
03/27/17 11:17 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Remind me how the motor attaches to the box.
Re: where to buy correct heater blower motor [Re: Stanton] #2278043
03/28/17 10:49 PM
03/28/17 10:49 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
has a plastic tube that fits in the hole on motor ans extends over to the box that has a hole to plug into.
Re: where to buy correct heater blower motor [Re: Stanton] #2278259
03/29/17 12:10 PM
03/29/17 12:10 PM
Ottawa, Ontario
L.R Helbling Offline
Ottawa, Ontario
Just finished a restore on a 71 B Body. The blower motor has a round opening in the side for a soft plastic vent tube to go from it to a hole in the firewall which leads back into the heater box. The front of the motor has 2 studs which line up to holes on a soft rubber seal on a rear metal plate which is secured to the box via sheet metal screws. There is a fibre paper gasket between the front of the motor and the soft rubber seal. Not sure if the A bodies used the metal blower plate or not.
Re: where to buy correct heater blower motor [Re: moparpro] #2278322
03/29/17 02:26 PM
03/29/17 02:26 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Right. So why not set the motor where it needs to be and drill new mounting holes.
Some people take restorations to ridiculous levels. The motor is completely hidden from view and will likely never be seen by human eyes again once installed. Just make the friggin thing work and forget about it.
Re: where to buy correct heater blower motor [Re: moparpro] #2278546
03/29/17 10:17 PM
03/29/17 10:17 PM
Ottawa, Ontario
Ottawa, Ontario
The blower is not hidden from view. The rear end of it pokes out from the firewall and is one of the most visible elements in an open engine bay. To some people correct restoration techniques and methodologies matter. I'd rather keep all of my original mounting holes and not have to drill through the firewall or the rear mounting plate of the heater box if I don't have to. Don't understand why you're getting so upset. You were the one asking to be reminded how it was mounted in one of the earlier posts.
Re: where to buy correct heater blower motor [Re: moparpro] #2278564
03/29/17 10:48 PM
03/29/17 10:48 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
if i couldn't find a replacement motor,
send your motor out to this guy and it will come back brand new..
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/738678/1/js-restorations.html
Re: where to buy correct heater blower motor [Re: L.R Helbling] #2278654
03/30/17 12:34 AM
03/30/17 12:34 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well I have a '69 B Body and my motor is in the back of the heater box and DOES NOT protrude into the engine compartment. And the OP clearly states "no air".
Apology accepted !
Re: where to buy correct heater blower motor [Re: Stanton] #2278751
03/30/17 09:37 AM
03/30/17 09:37 AM
Ottawa, Ontario
Ottawa, Ontario
So I guess this was just a facetious comment? Since you already know how it is mounted?
Re: where to buy correct heater blower motor [Re: moparpro] #2278775
03/30/17 10:48 AM
03/30/17 10:48 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Not at all. But I know for sure it doesn't protrude into the engine compartment.
Re: where to buy correct heater blower motor [Re: moparpro] #2278792
03/30/17 11:30 AM
03/30/17 11:30 AM
Ottawa, Ontario
Ottawa, Ontario
Yes, no argument as far as the 69 non air cars are concerned. I was just responding to how the blower motor attaches to the box. I have a non air 71 and the rear of the blower is clearly visible. Most Mopars of that Era, IMHO are visible over those that are hidden. At least the ones I've seen anyway.
Re: where to buy correct heater blower motor [Re: moparpro] #2278842
03/30/17 01:08 PM
03/30/17 01:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Well "most" isn't "all".
ALL 66-70 B-Body Plymouths and Dodges (non air) do not have an exposed blower motor.
