Re: where to buy correct heater blower motor
[Re: moparpro]
#2271377
03/17/17 09:03 PM
03/17/17 09:03 PM
Posts: 4,270 Morrow, OH
markz528
Morrow, OH
rockauto
FOUR SEASONS 35502
[Re: Stanton]
#2278259
03/29/17 12:10 PM
03/29/17 12:10 PM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
Remind me how the motor attaches to the box. Just finished a restore on a 71 B Body. The blower motor has a round opening in the side for a soft plastic vent tube to go from it to a hole in the firewall which leads back into the heater box. The front of the motor has 2 studs which line up to holes on a soft rubber seal on a rear metal plate which is secured to the box via sheet metal screws. There is a fibre paper gasket between the front of the motor and the soft rubber seal. Not sure if the A bodies used the metal blower plate or not.
[Re: L.R Helbling]
#2278654
03/30/17 12:34 AM
03/30/17 12:34 AM
Posts: 8,861 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The blower is not hidden from view. The rear end of it pokes out from the firewall and is one of the most visible elements in an open engine bay. To some people correct restoration techniques and methodologies matter. I'd rather keep all of my original mounting holes and not have to drill through the firewall or the rear mounting plate of the heater box if I don't have to. Don't understand why you're getting so upset. You were the one asking to be reminded how it was mounted in one of the earlier posts. Well I have a '69 B Body and my motor is in the back of the heater box and DOES NOT protrude into the engine compartment. And the OP clearly states "no air". Apology accepted !
[Re: Stanton]
#2278751
03/30/17 09:37 AM
03/30/17 09:37 AM
L.R Helbling
Ottawa, Ontario
Remind me how the motor attaches to the box. So I guess this was just a facetious comment? Since you already know how it is mounted?
[Re: moparpro]
#2278775
03/30/17 10:48 AM
03/30/17 10:48 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Originally Posted By Stanton Remind me how the motor attaches to the box.
So I guess this was just a facetious comment? Since you already know how it is mounted? Not at all. But I know for sure it doesn't protrude into the engine compartment.
