Anyone used Head Gasket Shims? #2266403
03/09/17 09:07 PM
03/09/17 09:07 PM
IMGTX Offline OP
IMGTX  Offline OP
Rebuilding the engine in my 92 Stealth.
It's a 3.0 SOHC that had a blown head gasket.
I had to have the block decked do to pitting on the block. As I am installing the Original pistons I noticed the pistons are above the deck at TDC. The head does not have a recess except for the valve pocket area.
If I bolted the heads on without a gasket the piston would hit the head. The head gasket MAY give me the clearance I need but I am checking ahead of the game.
Is this normal for those motors or do I need to replace the pistons with some below deck versions?
Bryan
Re: Anyone built a Chry/Mitsu 3.0? Piston deck height question. [Re: IMGTX] #2266578
03/10/17 02:42 AM
03/10/17 02:42 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I just rebuilt mine but it is a DOHC Turbo. However that doesn't sound right to me, we build quench in the old Mopars using .050 or so.
Sheldon
Sheldon
Re: Anyone built a Chry/Mitsu 3.0? Piston deck height question. [Re: RUNCHARGER] #2266906
03/10/17 05:36 PM
03/10/17 05:36 PM
IMGTX Offline OP
IMGTX  Offline OP
Sweet car.
Mine's Black too, but it's a 92 Base model. I have those side skirts to put on it, but first I have to get it running again.
I have seen mixed reviews as to whether the pistons are above deck.
The piston is .035 above the deck and the old compressed head gasket is .055 thick (.050 on the cylinder that was blown).
This gives me a head to piston clearance of .015 to .02 assembled. I think I am screwed.
Still gonna ask, how much is safe on these engines?
I'm thinking it's too close so I am looking but I haven't found a "Thick/Helper" Head Gasket for this motor.
Re: Anyone built a Chry/Mitsu 3.0? Piston deck height question. [Re: IMGTX] #2266987
03/10/17 07:52 PM
03/10/17 07:52 PM
RUNCHARGER Offline
RUNCHARGER  Offline
I agree with you that sounds scary.
Sheldon
Sheldon
Re: Anyone built a Chry/Mitsu 3.0? Piston deck height question. [Re: IMGTX] #2267599
03/11/17 07:39 PM
03/11/17 07:39 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I've never heard of doing it, but what if you used two gaskets,
it's worth a try rather than tossing the block or buying pistons that might be costly??
Joe
Re: Anyone used Head Gasket Shims? [Re: IMGTX] #2271347
03/17/17 08:03 PM
03/17/17 08:03 PM
IMGTX Offline OP
IMGTX  Offline OP
I have search the web and found no thick gaskets for my SOHC engine. I did for the DOHC but no luck on mine.
There is a company that sells .020 STEEL shims to shim the head that would do the trick
BUT
Has anyone ever used them? I've heard of Copper used with decent luck but Steel?
Does anyone know of where I could get the copper ones if they are better?
Any advice is much appreciated. wave
Re: Anyone built a Chry/Mitsu 3.0? Piston deck height question. [Re: IMGTX] #2271365
03/17/17 08:29 PM
03/17/17 08:29 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Why not take .030" - .035" off the top of the pistons?
Re: Anyone built a Chry/Mitsu 3.0? Piston deck height question. [Re: roadhazard] #2271371
03/17/17 08:54 PM
03/17/17 08:54 PM
IMGTX Offline OP
IMGTX  Offline OP
I have thought of that but I am weighing options right now.
These are the stock pistons and I haven't checked on the cost/viability yet of cutting them. I am leaning towards cutting them.
The advantage of shims is I could have the engine back in the car and on the road in about 9 days.
Cutting the pistons would set me back at least a month longer because of my time constraints.
I am leaving all options open right now. up
Re: Anyone used Head Gasket Shims? [Re: IMGTX] #2271390
03/17/17 09:23 PM
03/17/17 09:23 PM
NIB $29.98 ea plus the ride. 020" thick. Only have the two. EDIT Missed that we ain't talkin SB.
Re: Anyone used Head Gasket Shims? [Re: IMGTX] #2271685
03/18/17 12:11 PM
03/18/17 12:11 PM
CA
David Lee Offline
David Lee  Offline
CA
have you checked out cometic head gaskets, pricey but they might make a head gasket that could solve your problem
Ah...so many pedestrians, so little time...
Re: Anyone used Head Gasket Shims? [Re: David Lee] #2271696
03/18/17 12:21 PM
03/18/17 12:21 PM
IMGTX Offline OP
IMGTX  Offline OP
They look great but they dont make them fora SOHC just the DOHC.
Nobody give the low end engines any love. whiney
Re: Anyone used Head Gasket Shims? [Re: IMGTX] #2271835
03/18/17 04:21 PM
03/18/17 04:21 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
If you use steel I think you put a stock gasket on each side.
2011 Drag Pak Challenger
Re: Anyone used Head Gasket Shims? [Re: IMGTX] #2271929
03/18/17 07:07 PM
03/18/17 07:07 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Isn't that a Mitzi motor? Check on one of their forums, maybe somebody there could help.
Re: Anyone used Head Gasket Shims? [Re: IMGTX] #2271952
03/18/17 07:24 PM
03/18/17 07:24 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
If Cometic doesn't make a thick gasket, cut the pistons or relieve the chambers in the heads.
Re: Anyone used Head Gasket Shims? [Re: IMGTX] #2271970
03/18/17 08:02 PM
03/18/17 08:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Google copper head gaskets, if I remember right there's a company in Penn that will make any type or thickness up to 1/4 inch thick. Just o-ring the block if worried about sealing, they rent them. Use Hylomar blue spray to seal them.
Re: Anyone used Head Gasket Shims? [Re: IMGTX] #2272249
03/19/17 11:41 AM
03/19/17 11:41 AM
Valencia, España
NachoRT74 Online content
NachoRT74  Online Content
Valencia, España
deleted
Re: Anyone used Head Gasket Shims? [Re: IMGTX] #2272256
03/19/17 11:50 AM
03/19/17 11:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used one once on a 2.0 Mitsubishi turbo. It ran fine for a year then started using coolant. I don't know if it was the shim or if it cracked a head. The reason I used one in the first place is that my son had overheated to the point it had zero compression in all 4 cylinders. I cut the head beyond the recommended level. Hylomar was used per the instructions to seal coolant.
Doug
Re: Anyone used Head Gasket Shims? [Re: slantzilla] #2272925
03/20/17 12:48 PM
03/20/17 12:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Relieving the head is not an option looking at the picture of his head. He might have to cut the piston, but then he may run in P to V clearance issue depending on how much was taken off the block?
How much was taken off the block and how far was the piston in the hole before the block was decked ?
Re: Anyone used Head Gasket Shims? [Re: IMGTX] #2275112
03/24/17 12:24 AM
03/24/17 12:24 AM
IMGTX Offline OP
IMGTX  Offline OP
No idea how much was removed but IIRC the pistons were close to flush if not below the deck.
I decided to bite the bullet and try the shims. Innovative machine has them in different thicknesses so I went with a .030 shim.
I would have preferred to cut the pistons but I would have to have them pressed off then cut or new pistons. It would have been new pistons. Then I would wanted it re-balanced, and with no guarantee the lower deck and shaved heads wouldn't cause valve to piston problems. If I was gonna sink $1500 more in this motor, I would just buy a DOHC car and part it into mine.
I would swap the block but the Stealth block has a different oiling system than the other Chrysler/Mitsu 3.0's because the engine is mounted reversed of the other. I may or may not have had to find another Stealth/3000GT block. They may interchange but I never could get a definite answer.
I may regret it but I am willing to gamble. The worst I am out is about $300 in parts if it fails and I have to build another engine anyway. I should get $300 worth of driving in before it blows the head gasket anyway.
Thanks for the advice up
Wish me luck luck
