Anyone used Head Gasket Shims?
#2266403
03/09/17 09:07 PM
03/09/17 09:07 PM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
Rebuilding the engine in my 92 Stealth.
It's a 3.0 SOHC that had a blown head gasket.
I had to have the block decked do to pitting on the block. As I am installing the Original pistons I noticed the pistons are above the deck at TDC. The head does not have a recess except for the valve pocket area.
If I bolted the heads on without a gasket the piston would hit the head. The head gasket MAY give me the clearance I need but I am checking ahead of the game.
Is this normal for those motors or do I need to replace the pistons with some below deck versions?
Bryan
Re: Anyone built a Chry/Mitsu 3.0? Piston deck height question.
[Re: IMGTX]
#2266578
03/10/17 02:42 AM
03/10/17 02:42 AM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
I just rebuilt mine but it is a DOHC Turbo. However that doesn't sound right to me, we build quench in the old Mopars using .050 or so.
Sheldon
Sheldon
Re: Anyone used Head Gasket Shims?
[Re: IMGTX]
#2271347
03/17/17 08:03 PM
03/17/17 08:03 PM
IMGTX
I have search the web and found no thick gaskets for my SOHC engine. I did for the DOHC but no luck on mine. There is a company that sells .020 STEEL shims to shim the head that would do the trick BUT Has anyone ever used them? I've heard of Copper used with decent luck but Steel? Does anyone know of where I could get the copper ones if they are better? Any advice is much appreciated.
[Re: roadhazard]
#2271371
03/17/17 08:54 PM
03/17/17 08:54 PM
IMGTX
I have thought of that but I am weighing options right now. These are the stock pistons and I haven't checked on the cost/viability yet of cutting them. I am leaning towards cutting them. The advantage of shims is I could have the engine back in the car and on the road in about 9 days. Cutting the pistons would set me back at least a month longer because of my time constraints. I am leaving all options open right now.
[Re: IMGTX]
#2271390
03/17/17 09:23 PM
03/17/17 09:23 PM
RapidRobert
Does anyone know of where I could get the copper ones if they are better? NIB $29.98 ea plus the ride. 020" thick. Only have the two. EDIT Missed that we ain't talkin SB.
[Re: IMGTX]
#2271685
03/18/17 12:11 PM
03/18/17 12:11 PM
Posts: 301 CA
David Lee
CA
have you checked out cometic head gaskets, pricey but they might make a head gasket that could solve your problem
Ah...so many pedestrians, so little time...
[Re: David Lee]
#2271696
03/18/17 12:21 PM
03/18/17 12:21 PM
IMGTX
have you checked out cometic head gaskets, pricey but they might make a head gasket that could solve your problem They look great but they dont make them fora SOHC just the DOHC. Nobody give the low end engines any love.
[Re: IMGTX]
#2271835
03/18/17 04:21 PM
03/18/17 04:21 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I have search the web and found no thick gaskets for my SOHC engine. I did for the DOHC but no luck on mine. There is a company that sells .020 STEEL shims to shim the head that would do the trick Any advice is much appreciated. If you use steel I think you put a stock gasket on each side.
2011 Drag Pak Challenger
[Re: IMGTX]
#2271952
03/18/17 07:24 PM
03/18/17 07:24 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
If Cometic doesn't make a thick gasket, cut the pistons or relieve the chambers in the heads.
[Re: IMGTX]
#2272249
03/19/17 11:41 AM
03/19/17 11:41 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
deleted
[Re: slantzilla]
#2272925
03/20/17 12:48 PM
03/20/17 12:48 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
If Cometic doesn't make a thick gasket, cut the pistons or relieve the chambers in the heads. Relieving the head is not an option looking at the picture of his head. He might have to cut the piston, but then he may run in P to V clearance issue depending on how much was taken off the block? How much was taken off the block and how far was the piston in the hole before the block was decked ?
[Re: IMGTX]
#2275112
03/24/17 12:24 AM
03/24/17 12:24 AM
IMGTX
No idea how much was removed but IIRC the pistons were close to flush if not below the deck. I decided to bite the bullet and try the shims. Innovative machine has them in different thicknesses so I went with a .030 shim. I would have preferred to cut the pistons but I would have to have them pressed off then cut or new pistons. It would have been new pistons. Then I would wanted it re-balanced, and with no guarantee the lower deck and shaved heads wouldn't cause valve to piston problems. If I was gonna sink $1500 more in this motor, I would just buy a DOHC car and part it into mine. I would swap the block but the Stealth block has a different oiling system than the other Chrysler/Mitsu 3.0's because the engine is mounted reversed of the other. I may or may not have had to find another Stealth/3000GT block. They may interchange but I never could get a definite answer. I may regret it but I am willing to gamble. The worst I am out is about $300 in parts if it fails and I have to build another engine anyway. I should get $300 worth of driving in before it blows the head gasket anyway. Thanks for the advice Wish me luck
