CERAMIC BRAKE PADS AND SHOES #2267367
03/11/17 01:30 PM
03/11/17 01:30 PM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
HAS ANYONE TRIED THESE YET?IF SO COULD YOU SHARE YOUR THOUHTS ON THEM I WAS THINKING ABOUT BUYING SOME. THANKS
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2267373
03/11/17 01:42 PM
03/11/17 01:42 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I've used them in different applications..As a general overview they do their job well with a big improvement in performance..They WILL wear the drum/rotor much more than a standard pad so be prepared to keep an eye on the wear through the lifetime of the pads..
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2267381
03/11/17 01:52 PM
03/11/17 01:52 PM
I used em (76 A body 2.75" single caliper pistons) in a 65 dart DD & no issues/stopped OK but I drive like an old man so I did not come close to testing their behavior under more grueling conditions.
Re: CERAMIC BRAKE PADS AND SHOES [Re: RapidRobert] #2267475
03/11/17 04:07 PM
03/11/17 04:07 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
I had a 95 Ram as a second car, that I parked outside and didn't drive every day.
I had a lot of trouble with my front brakes, they'd go bad about every 10K miles. The rotors would look like the surface of the moon, and it became apparent to me that the metallic pads would rust to the rotor while sitting. I tried ceramic pads one year and they helped considerably with that problem! Performance wise they were as good or better. I can't speak for increased rotor wear as I was only getting 10K out of rotors prior to the switch to ceramic!
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2267491
03/11/17 04:32 PM
03/11/17 04:32 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
They will squeal at you occasionally.
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2267570
03/11/17 06:49 PM
03/11/17 06:49 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
They are a good street friendly compound. Much less dust than most original pads.
**Photobucket sucks**
Re: CERAMIC BRAKE PADS AND SHOES [Re: 70Cuda383] #2267708
03/11/17 10:51 PM
03/11/17 10:51 PM
IN
ahy Offline
ahy  Offline
IN
I run OE type ceramic on my DD's and well satisfied. I agree they are a good durable low dust street friendly pad. On my hot rod that I road track, I run a more race oriented semi metallic to take the heat better.
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2267911
03/12/17 10:54 AM
03/12/17 10:54 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a set on my 65 disc conversion.Been on at least 8 years.No problems.I use them on stuff at home when i do brakes if my relatives want to pay the price.My 65 stops straight even at 120 with no fade or pull with them.Lots better than the Bendix I removed .Rocky
Chrysler Firepower
Re: CERAMIC BRAKE PADS AND SHOES [Re: therocks] #2267913
03/12/17 10:57 AM
03/12/17 10:57 AM
moparx Online content
moparx  Online Content
what kind of bed-in procedure do ceramic pads like ?
beer
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2268090
03/12/17 04:20 PM
03/12/17 04:20 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I guess I`m going against the flow here but I don`t like them. I tried them a couple times. As stated they did squeal on occasion and it seemed like I needed more pedal pressure for stopping. I`ll stick with semi metallic pads.
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2268326
03/12/17 10:14 PM
03/12/17 10:14 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I break mine is as i did at the shop.Some low speed stops with cooling between.Then a few higher speed stops with some cooling between.never a noise from mone.Plus no dust on my mags.Rocky
Chrysler Firepower
Re: CERAMIC BRAKE PADS AND SHOES [Re: therocks] #2268335
03/12/17 10:28 PM
03/12/17 10:28 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Our Minivan would eat semi metallic pads every 30K, switched to ceramic and haven't changed them since. 60K + miles. Started using them on all the DDs in the family.
They stop great and do not make a mess on the wheels like semi metallic.
To counter the rotor wear argument, when I didn't catch the 30 k interval on the semi metallic, the rotors got chewed on, and here it he rust belt the rotors actually get some nasty rust rot on the surfaces requiring replacement anyhow.
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2268435
03/13/17 01:56 AM
03/13/17 01:56 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Are shoes available in ceramic? I see ceramic pads offered, but can't find any shoes for '69 A body.
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2268466
03/13/17 04:55 AM
03/13/17 04:55 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Switched to ceramic pads from metallic on my 1970 E Body no PB car. Switched from 1 1/8th MC piston to a 15/16th at same time. Now great brakes and no dirty wheels. Smaller piston equals greater braking pressure with lessened leg effort.
No squeal either.
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2268500
03/13/17 10:40 AM
03/13/17 10:40 AM
georgia
moparpro Offline OP
moparpro  Offline OP
georgia
yes they make ceramic shoes as well,google this name muscle car brakes they have them in a box kit for all muscle cars.
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2269236
03/14/17 11:59 AM
03/14/17 11:59 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I hate them, they always feel spongy/glazed and never work as well as even the cheapest of metallic pads IMO.
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2269314
03/14/17 01:31 PM
03/14/17 01:31 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Probably depends as much as anything on the specific compound
Re: CERAMIC BRAKE PADS AND SHOES [Re: moparpro] #2269333
03/14/17 02:08 PM
03/14/17 02:08 PM
central il.
second 70 Online content
second 70  Online Content
central il.
I put a set on my Silverado after going 100,000 on the factory pads. The local parts store only had cheap or ceramic and didn't recommend the cheap pads on a full size 4 x 4 and they hadn't had any problems with the ceramic and so far after a year I haven't had any problems either.
