Turn Signal Switch Assembly #226894
02/16/09 05:49 PM
02/16/09 05:49 PM
Brantford Ontario
69_SIX_PACK Offline OP
Brantford Ontario
A have a couple of Turn Signal Switch Assembly questions.
Would the Mopar Part 04293102 work for a 1971 Dodge Polara?
Are the B and C Body assembly the same?
Is there a better place to buy it than Chrysler?
Here is a link:
http://www.monicattichrysler.com/comersus/store/comersus_viewItem.asp?idProduct=3087
Says only A,B and E bodies
Thanks,
Re: Turn Signal Switch Assembly [Re: 69_SIX_PACK] #226895
02/16/09 06:32 PM
02/16/09 06:32 PM
NY
twodoorpost Offline
twodoorpost  Offline
NY
4293102 is for a non tilt column and a car with cornering lamps. Look at the pic and you will see 2 wiring harness connectors. It will still work but the 3 wire cornering lamp harness connector will be unused. If you need one for non tilt column without cornering lamps, you need 4293103, it doesn't have the 3 wire connector.
Re: Turn Signal Switch Assembly [Re: 69_SIX_PACK] #226896
02/16/09 06:59 PM
02/16/09 06:59 PM
Brantford Ontario
Brantford Ontario
I don't have cornering lights or a tilt column.
Thanks for the help.
Re: Turn Signal Switch Assembly [Re: 69_SIX_PACK] #226897
05/01/09 06:32 PM
05/01/09 06:32 PM
Brantford Ontario
Brantford Ontario
Anyone else have any feedback on this?
Re: Turn Signal Switch Assembly [Re: twodoorpost] #226898
05/01/09 08:16 PM
05/01/09 08:16 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Not to hijack this thread but will part number 4293103 fit in a 1968 Dodge Charger without any modifications? If so, is that part number still available through Chrysler?
Re: Turn Signal Switch Assembly [Re: badblack68] #226899
05/01/09 08:41 PM
05/01/09 08:41 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
3488477 = 71 B & C-Body non-tilt.
2947503 = 70 A, B & C-Body non-tilt.
2857241 = 68 B & C-Body non-tilt.
2857241 = 69 A, B & C-Body non-tilt.
You will need to find the superseded part numbers.
4293102 = 2947503, 3488477
Re: Turn Signal Switch Assembly [Re: Snoopy] #226900
05/02/09 12:11 AM
05/02/09 12:11 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
3488805: turn signal switch assy; 1970-76 A, B, E, C bodies ss to: 4293102 $50.10
2947801: turn signal switch 66-69 A body $53.35
I don't know if the numbers are any good anymore but these were that last known good #'s
Re: Turn Signal Switch Assembly [Re: badblack68] #226901
05/02/09 07:19 AM
05/02/09 07:19 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
No
