BB valve covers #2268082
03/12/17 04:06 PM
03/12/17 04:06 PM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
Anyone using these valve covers on there BB with aluminum heads?
https://i.ebayimg.com/images/m/m1xZLB1J8Du4ANfdOgc8MCw/s-l200.jpg
curious if they clear the rockers and pushrods.
Re: BB valve covers [Re: mopar dave] #2268126
03/12/17 05:20 PM
03/12/17 05:20 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I've seen them advertised on facebook, too. They should clear valve gear, since they are perimeter covers, but I would question distributor clearance myself.
[image][/image]
Re: BB valve covers [Re: mopar dave] #2268155
03/12/17 06:05 PM
03/12/17 06:05 PM
indy
E
eds dart Offline
eds dart  Offline
E
indy
am using Mancini racing polished covers on a low deck. they clear a stock distributor and cap with victor heads just fine.
Re: BB valve covers [Re: eds dart] #2268187
03/12/17 07:03 PM
03/12/17 07:03 PM
Mt Morris Michigan
Mt Morris Michigan
Yes. Using a victor head as well. Should clear valve trane and distributor. Thanks.
Re: BB valve covers [Re: mopar dave] #2268212
03/12/17 07:43 PM
03/12/17 07:43 PM
PA
Harry's Taxi 2 Offline
PA
Yes, they clear with Indy EZ heads, Hughes 1.6 and 1.5 rockers with the B3 geometry correction kit that raises the shafts a little and offsets them towards the intake side.
(edit...just noticed you were asking about victor heads)
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: BB valve covers [Re: Harry's Taxi 2] #2268282
03/12/17 09:32 PM
03/12/17 09:32 PM
Mt Morris Michigan
Mt Morris Michigan
Good to hear. I will get them then. Thanks
Re: BB valve covers [Re: mopar dave] #2268434
03/13/17 01:55 AM
03/13/17 01:55 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
They will not work on some heads,the bolt angle is different,I bought some & had to get some the use short studs,not the long bolts that KMJ have.
Re: BB valve covers [Re: CSK] #2268522
03/13/17 11:55 AM
03/13/17 11:55 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I have Victors, too. If my no-logo Indy cast covers have rocker clearance issues, I think my next option will be the 440 Source fabricated vc. I don't like those covers that use the long bolts through tubes for the main four fasteners.
Re: BB valve covers [Re: mopar dave] #2268528
03/13/17 12:01 PM
03/13/17 12:01 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I have the MOPAR cast AL. on my Victors, Hughes rockers, fit well, no leaks, plenty of room for a std. sized dist.
Joe
Re: BB valve covers [Re: mopar dave] #2268548
03/13/17 12:32 PM
03/13/17 12:32 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I have one MP cast aluminum, and one stock valve cover on my victors with Hughes 1.6 rockers. The stock ones need some hammer adjustment in the corner but fit. If those do anything should unless other rockers hang out way more. On a side note, don't over tighten MP cast Aluminum valve covers in the early hours of the morning before your first race of the season.
Re: BB valve covers [Re: BradH] #2268924
03/13/17 10:06 PM
03/13/17 10:06 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The 440 source is what I ended up getting to replace the KMJ junk.
Re: BB valve covers [Re: CSK] #2268971
03/13/17 10:47 PM
03/13/17 10:47 PM
BradH Offline
BradH  Offline
KMJ? confused
Re: BB valve covers [Re: mopar dave] #2269368
03/14/17 03:09 PM
03/14/17 03:09 PM
Jacksonville , Fl
V
Volare4life Offline
Volare4life  Offline
V
Jacksonville , Fl
Kmj is one of th main suppliers on ebay for those valve covers, I have a set on my iron headed 400bb, but I had to have my machine shop flatten them on the big belt sander, they were both 1/8 warped not flat lol
The answers are out there you just got to look hard enough
Re: BB valve covers [Re: Volare4life] #2269609
03/14/17 10:07 PM
03/14/17 10:07 PM
Mt Morris Michigan
Mt Morris Michigan
they are on the way. I will fit them this weekend and see how good or bad they are. I have another set on backorder that are sheet metal with carbon fiber film.
Re: BB valve covers [Re: mopar dave] #2269825
03/15/17 06:24 AM
03/15/17 06:24 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
They look like these that I use only they are black. I bought these from Mancini and I like them. They seal up good and have a baffle under the hole as I run a PCV valve and it does not suck any oil up as the baffle works good. I like them and I use the basic EZ heads. Ron
Re: BB valve covers [Re: 383man] #2269835
03/15/17 09:00 AM
03/15/17 09:00 AM
Mt Morris Michigan
Mt Morris Michigan
Yep. Look just like yours ron. Glad to hear your having good luck with them.
Re: BB valve covers [Re: mopar dave] #2270964
03/17/17 02:34 AM
03/17/17 02:34 AM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Any idea what brand you ordered? I checked out eBay tonight and saw a lot of people selling what looked like only a few different styles. I wonder how many companies are making basically the same thing, or if there is only one manufacturer of each style and many people selling the same stuff at way different prices?
Re: BB valve covers [Re: PorkyPig] #2270977
03/17/17 03:17 AM
03/17/17 03:17 AM
Mt Morris Michigan
Mt Morris Michigan
Dont know who makes them but i noticed the same as you. Different prices same product. They arrived today. Look good. I set them on a flat surface and no rocking. I will see how they fit this weekend.
Re: BB valve covers [Re: mopar dave] #2271151
03/17/17 01:57 PM
03/17/17 01:57 PM
BradH Offline
BradH  Offline
I'm interested in what you find out as for rocker clearance. The 440 Source covers description states the intake-side flange requires grinding additional clearance for Victor head rockers.
Re: BB valve covers [Re: BradH] #2271184
03/17/17 02:45 PM
03/17/17 02:45 PM
Mt Morris Michigan
Mt Morris Michigan
ill let ya know. usually the flange needs clearancing for pushrods.
