1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan #2268122
03/12/17 05:14 PM
03/12/17 05:14 PM
Western Ohio - formerly Southe...
hemid68 Offline OP
hemid68  Offline OP
I am putting a deepened 340 oil pan on my 416 stroker. Can I use the new style 1 piece oil pan gasket, without it leaking?
Or do I have to use the old style gasket with the 340 pan?
Re: 1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan [Re: hemid68] #2268149
03/12/17 05:53 PM
03/12/17 05:53 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
Not sure there is one, the one piece magnum pan gaskets are 360 size.
Re: 1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan [Re: gtsdude] #2268193
03/12/17 07:06 PM
03/12/17 07:06 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
They are magnum sized, not 360 sized.
360 sized implies it will fit a LA 360, it will not.
It will fit all Magnum engines though, both the 5.2 and the 5.9.
Don't be the exception.
Re: 1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan [Re: hemid68] #2268263
03/12/17 09:14 PM
03/12/17 09:14 PM
AndyF Offline
AndyF  Offline
Last time I did a 340 engine I looked all over for a one piece pan gasket but didn't find one. So unless someone tooled up to make one recently there is no such thing. The Magnum and LA 360 gaskets are close but not identical. I know some people interchange them but I think the dimensions are slightly different.
Re: 1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan [Re: hemid68] #2268276
03/12/17 09:29 PM
03/12/17 09:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You have to do more than just use the magnum gasket on an LA 360, it will leak.
I forget what you have to do though.
Here you go
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/5366036/site_id/1#import
Re: 1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan [Re: hemid68] #2268292
03/12/17 09:41 PM
03/12/17 09:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That one piece magnum gasket that is sometimes sold for all 360 by SCE...
WILL LEAK a bunch.
Been there, done that.
Re: 1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan [Re: hemid68] #2268354
03/12/17 10:54 PM
03/12/17 10:54 PM
hemid68 Offline OP
hemid68  Offline OP
Guys,
Thanks a lot. I did put a 360 one piece gasket on a magnum 360, with an old style truck pan, and it leaked like crazy. I used a magnum pan on it, with the one piece gasket, and it doesn't leak a bit in my Dakota.
So thanks for the clarification on the 340 style pan. I guess I'll just use the old style gasket, and make sure to install it correctly.
Thanks again,
Dan
Re: 1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan [Re: hemid68] #2268606
03/13/17 02:17 PM
03/13/17 02:17 PM
K
Kiddart Offline
Kiddart  Offline
K
I don't think they are made anymore but Miladon made a 1 piece LA 360 style. I have one on my car now and doesn't leak. it was around $40
Thank you
Kiddart
Re: 1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan [Re: hemid68] #2268608
03/13/17 02:19 PM
03/13/17 02:19 PM
K
Kiddart Offline
Kiddart  Offline
K
JEGS Performance Products 210495
One-Piece Oil Pan Gasket 1970-90 Small Block Chrysler 360
Thank you
Kiddart
Re: 1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan [Re: hemid68] #2268612
03/13/17 02:24 PM
03/13/17 02:24 PM
K
Kiddart Offline
Kiddart  Offline
K
sorry thought you needed 360
Thank you
Kiddart
