Re: 1 Piece Oil Pan Gasket on an Old Style 340 Oil Pan
[Re: gtsdude]
#2268193
03/12/17 07:06 PM
03/12/17 07:06 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not sure there is one, the one piece magnum pan gaskets are 360 size. They are magnum sized, not 360 sized. 360 sized implies it will fit a LA 360, it will not. It will fit all Magnum engines though, both the 5.2 and the 5.9.
[Re: hemid68]
#2268606
03/13/17 02:17 PM
03/13/17 02:17 PM
Posts: 1,552 Michigan
Kiddart
I don't think they are made anymore but Miladon made a 1 piece LA 360 style. I have one on my car now and doesn't leak. it was around $40
Thank you Kiddart
[Re: hemid68]
#2268608
03/13/17 02:19 PM
03/13/17 02:19 PM
Kiddart
JEGS Performance Products 210495
One-Piece Oil Pan Gasket 1970-90 Small Block Chrysler 360
Thank you Kiddart
[Re: hemid68]
#2268612
03/13/17 02:24 PM
03/13/17 02:24 PM
Kiddart
sorry thought you needed 360
Thank you Kiddart
