Guys running a Mopar distributor #2267636
03/11/17 08:56 PM
03/11/17 08:56 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
What curve kit/springs are you running to get full advance early by 2500/3000 or so? I just have the small factory spring left in there and I suspect its not strong enough.
It does have the fbo limiter plate.
Re: Guys running a Mopar distributor [Re: Hot 340] #2267653
03/11/17 09:15 PM
03/11/17 09:15 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
In the past I think we used a kit from Mopar which I don't think they sell anymore.
I run these now:
https://www.summitracing.com/parts/mrg-925b
They are from Mr. Gasket.
Re: Guys running a Mopar distributor [Re: Hot 340] #2267668
03/11/17 09:37 PM
03/11/17 09:37 PM
I use both of the Mr. Gasket 925 B springs on all my Mopar motors, street or strip up
I weld up the advance slots to limit the total amount of mechanical advance on the early non adjustable distributors so I can have between 14 to 18 BTDC at idle and no more than 34 to 36 total timing revved up above 2500 RPM on the B/RB and street Hemi motors thumbs
Re: Guys running a Mopar distributor [Re: Cab_Burge] #2267745
03/11/17 11:36 PM
03/11/17 11:36 PM
crabman173
crabman173
super lite springs just make a mess the only way to fly is use the FBO slotted plate which is IMO the BEST Mopar part on the market--you drop it in --on the right set of slots and BINGO you get that 15-18 degrees at idle so cool happy engine no matter the cam and it limits the mechanical advance just like welding up the slots--crazy lite springs are often overcome by idle RPM and thus the idle will "HUNT" around up and down RPM - wise causing a big PIA
Nobody on earth understands stock distributors better than Rick Erenburg--his written "teachings" are your path to happiness but not without that cheapo DREAM part the FBO plate
Look it up--buy one--live in happiness with a stock junk distributor
anybody still welding slots is just uninformed and needs some of those plates--I sleep with one under my pillow LOL
Re: Guys running a Mopar distributor [Re: Hot 340] #2267758
03/11/17 11:56 PM
03/11/17 11:56 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: Guys running a Mopar distributor [Re: 340Cuda] #2267789
03/12/17 12:46 AM
03/12/17 12:46 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I run these now:
thumbs thanks
Re: Guys running a Mopar distributor [Re: 70AARcuda] #2267792
03/12/17 12:48 AM
03/12/17 12:48 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Originally Posted By 70AARcuda
Gents, per my first post I already have the fbo plate. I need springs to control the advance RATE. My single small spring isn't strong enough to pull the weights back in after revving.
Re: Guys running a Mopar distributor [Re: Hot 340] #2267802
03/12/17 01:08 AM
03/12/17 01:08 AM
here's a chart that may help. the crane spring kit is no longer available but no big deal. EDIT the weight holes/pins are cleaned, no sticking?
Re: Guys running a Mopar distributor [Re: ] #2267858
03/12/17 03:35 AM
03/12/17 03:35 AM
After seeing Don screw a local nice guy racer over severely through his own incompetence I won't buy anything from him, unless there are no other choices and I'm dying twocents
BTW, using a set of springs that has the advance all in by 600 RPM prevents hunting shruggy scope
Better than locking in the advance on the distributors up twocents
Re: Guys running a Mopar distributor [Re: Hot 340] #2267876
03/12/17 07:27 AM
03/12/17 07:27 AM
pennsylvania
poboyengineering Offline
pennsylvania
This may be obvious, but the instructions show installation on a vacuum distributor. I have a tach drive unit with no vacuum. They are the same, right?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Guys running a Mopar distributor [Re: RapidRobert] #2267887
03/12/17 08:33 AM
03/12/17 08:33 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks! thumbs
Re: Guys running a Mopar distributor [Re: Cab_Burge] #2267968
03/12/17 12:57 PM
03/12/17 12:57 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
But that will require a very light spring and I can see a problem with the weights sticking in the advanced position. work
Re: Guys running a Mopar distributor [Re: poboyengineering] #2267971
03/12/17 01:02 PM
03/12/17 01:02 PM
I would lean toward yes since the FBO plate sits on the weight pins/under the cam plate & I would think both types would have similar weight advance systems there. if you have a "regular" dist handy you could eyeball that area & likely confirm it.
Re: Guys running a Mopar distributor [Re: DrCharles] #2267984
03/12/17 01:20 PM
03/12/17 01:20 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
iagree I have never been able to get the advance to return with springs that light. Personally, I like to have the advance all in as soon as I can while maintaining stable idle timing. Usually all-in around 1,600 or so. Some hardware stores have a selection of micro springs. I use those in combo with a stretched (weakened) stock small spring.
And you can also drill holes in the weights to lighten them if the advance comes in a little earlier than desired. Trial and error and testing, testing, testing.
twocents
Master, again and still
Re: Guys running a Mopar distributor [Re: Hot 340] #2268016
03/12/17 02:28 PM
03/12/17 02:28 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I Always used the stock dist, one light spring to bring it back to zero for easy starting. Once started it goes full advance ( timing light on balancer at 36) engine response is great when full advanced at 650 rpm. Ran stock factory dist to 7500 never one problem, at no cost. Ain't as pretty as an MSD but I didn't run show cars.
Re: Guys running a Mopar distributor [Re: DaveRS23] #2268020
03/12/17 02:33 PM
03/12/17 02:33 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
twocents
Get that heavy grease out the factory uses inside the rotor stem
Re: Guys running a Mopar distributor [Re: cudaman1969] #2268064
03/12/17 03:40 PM
03/12/17 03:40 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Do you drive on the street with full advance, or strip-only? What's the rest of your combo? work
Re: Guys running a Mopar distributor [Re: DrCharles] #2268134
03/12/17 05:36 PM
03/12/17 05:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Six different cars and seven different engines, from max wedge to Hemi, all race cars, I don't have a race engine on the street, haven't had one on the street since 1974. Street "driving" needs a whole different setup, basicly because of the lack of decent fuel. If there was still 260 gas I'd run full advance
Re: Guys running a Mopar distributor [Re: cudaman1969] #2268137
03/12/17 05:40 PM
03/12/17 05:40 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I do the same. I clean up a stock electronic distributor and use white lithium grease on the weights and 925-B springs. It starts easy yet acts like a locked out distributor at 36° total when running. The distributor triggers a hidden MSD 6AL with an adjustable rev limit. Usually set it at 6400 rpm. Runs and drives great with this setup! I do use 91 octane no ethanol but it will run on E-10 lower octane with this same setup. I have to pull a couple of degrees for crappy gas.
'63 Dodge 330
11.19 @ 121 mph
Re: Guys running a Mopar distributor [Re: Hot 340] #2268225
03/12/17 08:11 PM
03/12/17 08:11 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I had 2 factory light springs from a basic elec dizzy. All in by 2300 IIRC...the Mr. G springs were WAY too light. all in by 1500...
my next step was going to be drilling out the weights
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
