Re: Guys running a Mopar distributor
[Re: Cab_Burge]
#2267745
03/11/17 11:36 PM
03/11/17 11:36 PM
crabman173
crabman173
super lite springs just make a mess the only way to fly is use the FBO slotted plate which is IMO the BEST Mopar part on the market--you drop it in --on the right set of slots and BINGO you get that 15-18 degrees at idle so cool happy engine no matter the cam and it limits the mechanical advance just like welding up the slots--crazy lite springs are often overcome by idle RPM and thus the idle will "HUNT" around up and down RPM - wise causing a big PIA Nobody on earth understands stock distributors better than Rick Erenburg--his written "teachings" are your path to happiness but not without that cheapo DREAM part the FBO plate Look it up--buy one--live in happiness with a stock junk distributor anybody still welding slots is just uninformed and needs some of those plates--I sleep with one under my pillow LOL
[Re: Hot 340]
#2267758
03/11/17 11:56 PM
03/11/17 11:56 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Hot 340]
#2267802
03/12/17 01:08 AM
03/12/17 01:08 AM
RapidRobert
here's a chart that may help. the crane spring kit is no longer available but no big deal. EDIT the weight holes/pins are cleaned, no sticking?
[Re: Hot 340]
#2267876
03/12/17 07:27 AM
03/12/17 07:27 AM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
This may be obvious, but the instructions show installation on a vacuum distributor. I have a tach drive unit with no vacuum. They are the same, right?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: poboyengineering]
#2267971
03/12/17 01:02 PM
03/12/17 01:02 PM
RapidRobert
This may be obvious, but the instructions show installation on a vacuum distributor. I have a tach drive unit with no vacuum. They are the same, right? I would lean toward yes since the FBO plate sits on the weight pins/under the cam plate & I would think both types would have similar weight advance systems there. if you have a "regular" dist handy you could eyeball that area & likely confirm it.
[Re: DrCharles]
#2267984
03/12/17 01:20 PM
03/12/17 01:20 PM
Posts: 12,071 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
BTW, using a set of springs that has the advance all in by 600 RPM prevents hunting But that will require a very light spring and I can see a problem with the weights sticking in the advanced position. I have never been able to get the advance to return with springs that light. Personally, I like to have the advance all in as soon as I can while maintaining stable idle timing. Usually all-in around 1,600 or so. Some hardware stores have a selection of micro springs. I use those in combo with a stretched (weakened) stock small spring. And you can also drill holes in the weights to lighten them if the advance comes in a little earlier than desired. Trial and error and testing, testing, testing.
Master, again and still
[Re: DaveRS23]
#2268020
03/12/17 02:33 PM
03/12/17 02:33 PM
Posts: 8,249 fredericksburg,va
cudaman1969
fredericksburg,va
BTW, using a set of springs that has the advance all in by 600 RPM prevents hunting But that will require a very light spring and I can see a problem with the weights sticking in the advanced position. I have never been able to get the advance to return with springs that light. Personally, I like to have the advance all in as soon as I can while maintaining stable idle timing. Usually all-in around 1,600 or so. Some hardware stores have a selection of micro springs. I use those in combo with a stretched (weakened) stock small spring. And you can also drill holes in the weights to lighten them if the advance comes in a little earlier than desired. Trial and error and testing, testing, testing. Get that heavy grease out the factory uses inside the rotor stem
[Re: DrCharles]
#2268134
03/12/17 05:36 PM
03/12/17 05:36 PM
cudaman1969
fredericksburg,va
I Always used the stock dist, one light spring to bring it back to zero for easy starting. Once started it goes full advance ( timing light on balancer at 36) engine response is great when full advanced at 650 rpm. Do you drive on the street with full advance, or strip-only? What's the rest of your combo? Six different cars and seven different engines, from max wedge to Hemi, all race cars, I don't have a race engine on the street, haven't had one on the street since 1974. Street "driving" needs a whole different setup, basicly because of the lack of decent fuel. If there was still 260 gas I'd run full advance
[Re: cudaman1969]
#2268137
03/12/17 05:40 PM
03/12/17 05:40 PM
Posts: 4,672 Wichita
GY3
Wichita
I Always used the stock dist, one light spring to bring it back to zero for easy starting. Once started it goes full advance ( timing light on balancer at 36) engine response is great when full advanced at 650 rpm. Ran stock factory dist to 7500 never one problem, at no cost. Ain't as pretty as an MSD but I didn't run show cars. I do the same. I clean up a stock electronic distributor and use white lithium grease on the weights and 925-B springs. It starts easy yet acts like a locked out distributor at 36° total when running. The distributor triggers a hidden MSD 6AL with an adjustable rev limit. Usually set it at 6400 rpm. Runs and drives great with this setup! I do use 91 octane no ethanol but it will run on E-10 lower octane with this same setup. I have to pull a couple of degrees for crappy gas.
[Re: Hot 340]
#2268225
03/12/17 08:11 PM
03/12/17 08:11 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I had 2 factory light springs from a basic elec dizzy. All in by 2300 IIRC...the Mr. G springs were WAY too light. all in by 1500...
my next step was going to be drilling out the weights
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
