Who sells Griner trans brake solenoid #2266439
03/09/17 10:06 PM
03/09/17 10:06 PM
kalamazoo, MI.
VIPERDUST Offline OP
kalamazoo, MI.
I have been trying to find a new electric solenoid for my 904 Griner transbrake. Griner's phone is disconnected. Who else sells or deals for Griner? Thanks, Matt
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266447
03/09/17 10:19 PM
03/09/17 10:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
try Keith at 727 Specialists.... I have a couple, but they come with free brakes attached! smile
Re: Who sells Griner trans brake solenoid [Re: J_BODY] #2266515
03/10/17 12:16 AM
03/10/17 12:16 AM
kalamazoo, MI.
kalamazoo, MI.
I called him, and he was not able or willing to help.
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266533
03/10/17 12:53 AM
03/10/17 12:53 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I would call Hughs or John Cope at CRT to see if they can help you out.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266547
03/10/17 01:28 AM
03/10/17 01:28 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Take it it's like the one on the left....
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266548
03/10/17 01:30 AM
03/10/17 01:30 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Appears to be the same as this other early 90's Griner I have here....
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266632
03/10/17 06:16 AM
03/10/17 06:16 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
what is it with Grinner Brakes? i'm down under & Grinner brakes are rare, i only know 2 racers with them & both have had solenoid issues. Yet whenever someone wants a brake recommendation everyone says Grinner? Im kinda glad i have A&A but was thinking of trying one of John Copes own brand next build. anyone using his on here?
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266658
03/10/17 09:57 AM
03/10/17 09:57 AM
Indianapolis, In. area
BTBelvedere Offline
BTBelvedere  Offline
Try Joe at Tranzact.
Re: Who sells Griner trans brake solenoid [Re: J_BODY] #2266684
03/10/17 11:31 AM
03/10/17 11:31 AM
kalamazoo, MI.
kalamazoo, MI.
Yes J-body, like the one on the left. CRT doesn't have any, and he said good luck getting hold of Griner. CRT said to try tranz-act, but was unsure of there quality. Was told TCI was the same, but the tech. at TCI said they were not....... still looking.
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266719
03/10/17 12:49 PM
03/10/17 12:49 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
They were damn good brakes Rebel.... that's why.
Just curious Vdust.... no continuity on solenoid? i looked at the piece I have in the second pict and it's definitely something made in house so finding a replacement might be difficult as you may well know. Funny thing is that I know this brake worked in the trans it came out of, but I hit it with 12 volts this am and was not greeted to a "snap" that I thought I would see/hear.
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266722
03/10/17 12:56 PM
03/10/17 12:56 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I've got a 904 with the newer style Griner in it (like the first pict). Might have to pull the pan and compare. Currently I'm running a Pro Trans brake in my Duster.
Re: Who sells Griner trans brake solenoid [Re: J_BODY] #2266755
03/10/17 01:37 PM
03/10/17 01:37 PM
kalamazoo, MI.
kalamazoo, MI.
It appears to be dead, I have tried powering it up on the bench, nothing at all. Nothing in or out. no need to pull yours apart
Re: Who sells Griner trans brake solenoid [Re: rebel] #2266759
03/10/17 01:43 PM
03/10/17 01:43 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have one of John's brakes but haven't ran it yet. Waiting on a pan from Steff's and the weather.
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266798
03/10/17 02:37 PM
03/10/17 02:37 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Friend of mine runs a CRT brake. So far no complaints....
While I expected some kind of solenoid movement on the Griner, I'm wondering if fluid psi against it works into the equation. Like I said, the trans this brake was in worked fine.
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266803
03/10/17 02:49 PM
03/10/17 02:49 PM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
See if you can disassemble the solenoid from the assembly to get a number off it to purchase the solenoid only.
The assembly that the solenoid is in is just a modified Governor body out of a 727 trans (clever use of spare parts LOL).
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266823
03/10/17 03:15 PM
03/10/17 03:15 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Call Pro Trans.
Re: Who sells Griner trans brake solenoid [Re: J_BODY] #2266866
03/10/17 04:04 PM
03/10/17 04:04 PM
B.C. Canada
hankcrank Offline
hankcrank  Offline
B.C. Canada
Used the same Griner for over 20 years with no problem if I hit the button when the car is not running the solenoid will only engage once (click) because I think it needs the trans running to reset the solenoid. If I am not mistaken Griner uses the line pressure to release the brake so that maybe why you do not hear it engage. good luck
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2266911
03/10/17 05:42 PM
03/10/17 05:42 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
tranzact uses the same solenoid...got one brake in use that I bought back in 1993...quality must be pretty good.
Tony
70 AARCuda Vitamin C
Re: Who sells Griner trans brake solenoid [Re: hankcrank] #2266913
03/10/17 05:44 PM
03/10/17 05:44 PM
kalamazoo, MI.
kalamazoo, MI.
Thanks for the replies. After the trans was refreshed, I had the car running, had all the forward gears, but put it in N and hit the trans button for reverse, and nothing. Got checking, and have power to the solenoid, but solenoid has no response, pulled valve body, removed solenoid, bench tested. Solenoid does not push out, or pull in when I have it extended. Looks like I will be sending the valve body to Tranzact, for Joe is the only one who says he can fix it. Fingers crossed.
Re: Who sells Griner trans brake solenoid [Re: VIPERDUST] #2267064
03/10/17 10:07 PM
03/10/17 10:07 PM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
try Dave at proformance he has a guy that rebuilds them 1- 815-308-5161
